8 codes for cel and occ. traction control
Results 1 to 4 of 4
Thread: 8 codes for cel and occ. traction control
    SKULL is offline [OP]
    Nov 2013
    5
    Po171
    Po106
    Po15a
    Po15b
    Po507
    Po69e
    Po1101
    Po171
    And I get the service traction control from time to time. I was reading the sticky for the leading pcv valve cover issue. I have the 500 rpm rough idle sometimes stall issue like the pvc thread. Got a little oil around the oil cap and get about 6-8 mpg less then I use to when I bought it. Just wanted to double check that this sounds like the same problem before I throw money at it
    Handbrake Released JerTM's Avatar
    156
    year, engine, model?
    DesPlaines Il
    5,455
    I'll assume this is a 1.4T only because I've never read of the P0171 coming up from the 1.8 gang.
    Based on your engine operation description, I'm inclined to agree the cam cover/PCV failure is likely.
    Remove the plastic spark plug/coil cover, start the engine, locate the PCV breather hole (glued in disc area) and put your finger tip against it.
    If the valve has failed there will be vacuum present at the hole.
    If vacuum is present, the cover/valve assembly is a 5year/100k warranty part so you may have a no charge repair coming your way.
    The remaining codes are likely resultant and will not return once the P0171 is resolved.......BTW....make sure the dipstick is fully seated....a unseated dipstick can create this code as well.
    Regarding the ABS light......I suspect you may be experiencing a result of the high resistance ground cable that has been identified by Chevrolet.
    The replacement is covered by a ten year warranty extension and probably should be undertaken before any further time is wasted for diagnosis.
    Good luck!
    Rob
    Nov 2013
    5
    sorry I forgot to mention. 2012 1.4t 6 speed. okay ill have to give it a try and ill make the schedule for my water pump recall and see if the dealer will take care of the pcv to if it is under warrenty
  7. Remove Advertisements
  1. 2011 Cruze LS with 1.8L, cel (MIL) codes P0660 & P0258
    By Stu Corpe in forum General Discussion
    Last Post: 12-19-2014, 05:02 PM
  2. CEL accompanied by three codes
    By NYCruze2012 in forum Gen1 1.4L Turbo
    Last Post: 11-24-2014, 10:57 AM
  3. CEL 6 codes.
    By JWishnok in forum Gen1 1.4L Turbo
    Last Post: 11-15-2014, 03:19 PM
  4. Replies: 20
    Last Post: 03-06-2013, 06:39 PM
  5. Replies: 18
    Last Post: 01-16-2013, 09:19 AM
