2011 chevy cruze 6 speed eco
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: 2011 chevy cruze 6 speed eco
    rnnhoover is offline [OP]
    Oct 2017
    23
    U0140, P2227, P2228, P0420, P0299. Ive replaced many parts to include the turbo all the lines coming in and out, rerouted the check valve on the intake manifold, MAF sensor, baro sensor, map sensor, turbo boost sensor and probably more just cant think of any more at the time. I know the P0420 is an exhaust leak/gutted catalytic converter i created when replacing the O2 sensor after the catalytic converter. I gutted the catalytic converter because i thought maybe it was bad then changed the rear O2 sensor and ended up having to cut the exhaust and pull it off to remove the O2 sensor because it wouldnt come out. I pulled the brake booster hose out as well and blew smoke with my vapor cig in there with no visable leaks, dont know if that would replicate a smoke test to the extent it needs to but afterwords pulled the intake hose off and there was smoke in there (so i think it worked) Any questions and ill do what i can to answer them. I will appreciate all the help i can get.
    5,303
    What is the actual question?
    Oct 2017
    23
    Why it wont boost over 4 psi
    Oct 2017
    14
    You have done a lot! What are the symptoms you're having? As in actual running problems?
    5,303
    Quote Originally Posted by rnnhoover View Post
    It is possible the bypass valve spring has gotten weak, but I would wait for more techs to chime in, I am not a mechanic.
    Oct 2017
    23
    Im getting all the codes as posted above, with a mechanical boost gauge showing 4 psi. This might or might not be related but the DIC is showing a average of 17 mph. The average mpg shows 29 (i believe ill check again) but i can almost see my fuel gauge dropping while driving it seems to me to be getting terrible gas mileage. I can go through about 1/4 a tank and drive at the most 80 miles.
    Oct 2017
    23
    Quote Originally Posted by staticcase View Post
    Also forgot to mention that if i pull the vacuum hose off the waste gate actuator ( wont do it again as i know i playing with fire) it will boost properly. Im thinking at this point its going to be a computer issue, but just my opinion.
    Oct 2017
    23
    The baypass valve was new with the turbo.
    Oct 2017
    14
    I wouldn't think the wastegate spring to be bad straight from the factory, though I've seen it before...
    I've had the underboost problem before but it went away, and I still have the P0420 and it makes my car run horrible at higher RPMs...
    In your case, I would definitely lean towards the bcm or ECU since you changed the baro sensor already and there are two codes for it.
    That being said, I feel you have two different issues going on, but it could all be stemming from a bad ECU. Not the gutted cat part, but the underboost and bad barometer readings.
    Just my two cents.
    Oct 2017
    23
    Just my two cents.
    I appreciate the help. Is there anyway to check that spring? Something else i didnt mention is oil in the throttle body, intake manifold etc...
  1. Manual Transmission Howl 2011 Eco 6 speed, anyone else?
    By PonchoIndian in forum Gen1 1.4L Turbo
    Last Post: 04-06-2016, 08:00 PM
  2. Eco-Modding 2011 Chevy Cruze Eco
    By mjspiess in forum Fuel Economy
    Last Post: 10-11-2014, 08:22 PM
  3. Just picked up a 2011 Cruze ECO 6-speed manual
    By MattW in forum CruzeTalk New Member Introductions
    Last Post: 11-06-2013, 09:19 AM
  4. 2011 Chevy Cruze Eco Owner
    By RTShadow in forum CruzeTalk New Member Introductions
    Last Post: 04-23-2013, 07:46 PM
  5. 2011 Chevy Cruze ECO
    By GMMillwright in forum General Discussion
    Last Post: 03-15-2011, 07:15 PM
