p0171 P1011 Rough Idle when Temps below freezing. HELP
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By unitednations161
Thread: p0171 P1011 Rough Idle when Temps below freezing. HELP
    154
    2011 chevy cruze eco 135,000 milesSo I took my car to the shop and got a smoke test for the p0171 code and +22 LTFT, They found the PCV leaking. My wife went and told them to replace it ( I was sleeping SMH) well $270 later. (it makes me sick over a $48 part I could of did in my sleep). I get the car back. I drive it home around 45 Degrees out, LTFT is staying around 0 to +7. I start it after work, Temps in the 20s it idles like crap, and almost stalls twice. LTFT was at +32 and a pending p0171 code. Drove it home, LTFT was staying around +7, idle after warm up around +6. Got home, tried to see if there was another air leak, I cant find one, after messing around it set of a p1011 code, Im not sure if it was from me. It set off that code once before, but when I reset it it never came back just the p0171. Does anyone know correct MAF readings on the cruze?And any ideas on my Rough idle only on a Very cold temp start, and high LTFT still after pcv was changed?PS Manisfold does have the orange check valve present.
    154
    Freeze frame report generated by Torque for Android
    Vehicle Manufacturer: Chevrolet
    Vehicle Calibration ID: 126
    Freeze frame information:
    Fuel Status = 0 byte
    Engine Load = 70.98 %
    Engine Coolant Temperature = 219.2 °F
    Fuel Trim Bank 1 Short Term = 0 %
    Fuel Trim Bank 1 Long Term = 33.594 %
    Fuel pressure = 61.351 psi
    Intake Manifold Pressure = 17.695 psi
    Engine RPM = 2,132 rpm
    Speed (OBD) = 68.972 mph
    Timing Advance = 2.5 °
    Intake Air Temperature = 48.2 °F
    Mass Air Flow Rate = 30.15 g/s
    Throttle Position(Manifold) = 50.98 %
    Run time since engine start = 419 s
    Fuel Level (From Engine ECU) = 90.196 %
    Distance travelled since codes cleared = 23.612 miles
    Evap System Vapour Pressure = 0.25 Pa
    Barometric pressure (from vehicle) = 14.504 psi
    Catalyst Temperature (Bank 1,Sensor 1) = 1,520.6 °F
    Voltage (Control Module) = 14.467 V
    Engine Load(Absolute) = 103.922 %
    Commanded Equivalence Ratio(lambda) = 1
    Relative Throttle Position = 37.647 %
    Ambient air temp = 44.6 °F
    Absolute Throttle Position B = 50.196 %
    Accelerator PedalPosition D = 38.824 %
    Accelerator PedalPosition E = 19.216 %
    End of report.
    154
    Anything that sticks out besides fuel trim?
    P0171 was set
    Jan 2013
    N/W Indiana
    325
    Fuel pressure seems a little high, but then again it appears the throttle was at 50%.
    I'm guessing a vacuum leak somewhere. Maybe smoke machine it? (side note, I'm chasing an unusually high LTFT myself and am in the process of making a homemade smoke machine )
    154
    How are you making it? I Tried with a hose and a Cigar ( Its rough living in an apartment) But I couldn't see anything. But I did enjoy the cigar. Fuel Pressure is around 48 most of the time. I must of been going up a hill on the highway when it actually set.
    mikestony likes this.
    Jan 2013
    N/W Indiana
    325
    Quote Originally Posted by unitednations161 View Post
    I'm making it out of an empty paint can following the instructions from here:
    Make Your Own Smoke Machine - E46Fanatics
    with some slight changes
    There are also many YouTube videos about it too.
    Fuel pressure is the same for me too.
    154
    Well if I don't get to it until I go back home, let me know what is leaking on your car.
    154
    Quote Originally Posted by mikestony View Post
    I'm making it out of an empty paint can following the instructions from here:Make Your Own Smoke Machine - E46Fanaticswith some slight changes There are also many YouTube videos about it too.Fuel pressure is the same for me too.
    alright thank you
    Jan 2013
    N/W Indiana
    325
    Will do
  1. CEL code P0171 and rough idle on 2011 Eco
    By three.one.seven in forum Gen1 1.4L Turbo
    Last Post: 02-10-2017, 02:30 PM
  2. P0171 code without rough idle
    By krush in forum Gen1 1.8L
    Last Post: 11-23-2015, 06:57 PM
  3. rough idle - valve cover (p0171) twice in 2yrs
    By bb1 in forum Gen1 Service Issues
    Last Post: 11-19-2015, 07:10 AM
  4. Fault Code P0171/rough idle
    By buckeyewalt in forum General Discussion
    Last Post: 01-24-2015, 05:19 PM
