2012 Cruze boiling coolant in reservoir. - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Like Tree6Likes
Thread: 2012 Cruze boiling coolant in reservoir.
  1. #21
    fyrftr422 is offline [OP]
    Driver's Ed fyrftr422's Avatar
    Aug 2012
    ON, Canada
    42
    Thanks for the info !!!!
    2012 Chevrolet Cruze LT/RS
  3. #22
    Aug 2018
    Rancho Cucamonga, Ca.
    Coolant reservoir leak
    Today my daughters 2012. Cruze had very little coolant in the reservoir. Not sure where it is leaking from or where the coolant went . I went a head and changed the cap out and removed the unit and checked for cracks underneath. This is the second time I have filled the case.
  4. #23
    2nd Gear CRUISE-CRUZE's Avatar
    USA
    431
    If you will read my post you will learn that the gauge we have is useless, you will boil the coolant without even knowing it! Then the original thermostat is opening "too high" so if you have air into the system or your system is not very well pressurized then you will boil the coolant to a much lower temperature. I did a lot of tests on a few Eco and replacing the thermostat was the best solution. These days are -5F in my area and had no issues with the heater, and during the summer also no more boiling coolant due to the new thermostat. I did the change for a few other cars and none of my friends had issues anymore. If you argue about the thermostat is opening "too low" and "performances" then let me tell you that I didn't see any major change on MPG..
  6. #24
    Aug 2012
    ON, Canada
    42
    Well, I have a new reservoir tank and cap arriving within a few days, with the beefier O-rings. This should solve my pressure issue (assuming that is what is happening) so we'll see if the new thermostat does the trick. It already boiled with it, but hopefully, with the pressure situation solved, should be good but replacing the thermostat alone, was not the solution.
  7. #25
    24,797
    Quote Originally Posted by fyrftr422 View Post
    Get some coolant dye and put it in once you're done with the swap out. This dye leaves a visible residue near any leaks.
    2018 Honda Clarity Touring PHEV - Forest Green w/Tan interior (wife's car)
    2017 Volt LT - Heather Gray; black bow ties, Hidden Content
    2012 ECO MT (Hidden Content ) - Black Granite/Cloth; Hidden Content ; Hidden Content ; OEM Fogs w/Chrome Covers; Hidden Content ; Hidden Content ; Hidden Content
    2002 Pont Montana AWD (traded for 2012 LS MT @182K miles - title transferred to son on college graduation)
  8. #26
    Aug 2012
    ON, Canada
    42
    Good call, I've heard others were given it by their local GM dealership.
  9. #27
    24,797
    I got mine free but it was while my Cruze was under the B2B warranty. Even if it's not free, a bottle is only $10-15 so it's well worth it to track down leaks.
    fyrftr422 likes this.
  10. Remove Advertisements
  1. FIX: Coolant Odors/Coolant Loss From Reservoir
    By Blue Angel in forum Gen1 Service Issues
    Last Post: 03-12-2019, 01:12 AM
  2. Replies: 17
    Last Post: 03-14-2018, 02:35 AM
  3. 2011 chevy cruze 1.4 overheating boiling over
    By Tormal1 in forum CruzeTalk New Member Introductions
    Last Post: 08-17-2017, 09:38 AM
  4. Replies: 5
    Last Post: 07-24-2013, 09:30 AM
  5. Coolant Boiling
    By twclark41 in forum General Discussion
    Last Post: 09-07-2012, 09:49 PM
