Motor overheated
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By ChevyGuy
  • 1 Post By Blasirl
Thread: Motor overheated
    47
    Motor overheated
    Hi all,
    I left work today and noticed that my Cruze, (2012 1.4L), ran rough below 1500 rpm. The steering wheel was vibrating. Above that the motor smoothed out, but it did not accelerate properly. Then as I left red lights I heard a very brief "chirping" sound.
    10 minutes later I noticed that the temp gauge was in the red, and I stopped immediately. I saw no fluid in the coolant tank, and I called a tow truck.
    **My car has 145,000kms, and it has had two transmission-fluid changes, a coolant change, (-recently), and has oil/filter changes every 5000kms.
    Any idea what happened? My mechanic isn't back to work until Monday....
    Thanks for any help.
    ChevyGuy's Avatar
    US
    7,333
    The Cruze is known for a number of issues that cause coolant leaks. Two big ones are the overflow tank connection and the water outlet. The water pump is another issue, but I'd expect that to be a slow leak.
    Ravenkeeper likes this.
    '13 LTZ
    Prior rides:
    '67 Chevy II, 250 ci/auto
    5,521
    Seeing that you just had a coolant change, whomever did it may not have "burped" the cooling system enough.
    47
    Thank you for the replies. My mechanic said a plastic coolant housing failed. Apparently many cars run plastic parts in their coolant systems nowadays, (-cost cutting), and they fail more often. Cost of tow: 200.00 Cost of repair: 400.00
    Thank you Chevy.
  7. Remove Advertisements
  1. Replies: 14
    Last Post: 02-26-2018, 09:28 PM
  2. Engine Overheated
    By Nobody in forum Gen1 1.4L Turbo
    Last Post: 12-04-2017, 06:20 PM
  3. Replies: 1
    Last Post: 04-02-2017, 03:41 PM
  4. Diesel Overheated
    By Ger8mm in forum Gen1 Diesel Technical Discussion
    Last Post: 06-03-2015, 08:54 AM
  5. Replies: 21
    Last Post: 12-06-2013, 12:48 PM
