cruze ac codes ?
Results 1 to 3 of 3
  • 1 Post By fl38583
Thread: cruze ac codes ?
    fl38583 is offline [OP]
    Feb 2019
    indiana
    cruze ac codes ?
    Ac off due to high engine temps??
    Yes, what a nice day - it was raining hard and not warm but near 45 degrees I just got onto the interstate I 69 headed to work everything normal then a code pops up saying no AC due to high engine temps?? I always look at my gauges and the temperature gauge is reading cold plus I did not ever see it anywhere near normal but warm air was coming out the vents. So I pulled off next exit to a gas station to check it out. pulled hood latch release cooling fan is running but engine does not feel hot. Turned car off checked all fluids everything is fine - took cap off the pressure tank did not steam or blow off, finally stuck finger in coolant it was not hot. After calling work telling them I am having car issues checked hose for heat when squeezed the in the pressure tank rose and fell on both upper and lower hose. After waiting about 20 minutes started for home then I pulled of again just to make sure it was not getting hot and the gauge had stopped working or something - No after another inspection it is not hot - decided to drive home and park about five away to home and I did not see the need to get it towed because it not hot. Watched the gauge it was working just not getting to normal temperature or off cold to much. Got it home parked it a took my rust but trust Chevy venture 259000 on it to work - not problems. Monday after letting it sit all week end started it up code still there engine is definitely cold but all thing the same - cooling fan running code still there. Mine and a co workers thought are that the thermostat stuck open and this code is in there because it does not get to operating temperature so it can run efficiently - the code is really because it does not get to operating temperature. Does this sound right and has anyone had similar thing happen. the cruze only has 62000 on it.
    Drag Racing Champion
    Nov 2017
    1,679
    It's a common issue to which you'll find lotsa threads.
    Feb 2019
    indiana
    took it to dealer, but on the way the the themostat must have come unstuck because all the sudden the code went away I heard the fan shut off,and the gauge moved to normal position. The dealer could not find anything but I had them change the oil and check it over good. So I do think it was the thermostat.
    Ravenkeeper likes this.
  1. HELP! No AC and multiple codes
    By Cepromotion in forum Gen1 Service Issues
    Last Post: 08-08-2018, 12:54 AM
  2. Replies: 20
    Last Post: 07-09-2018, 12:09 PM
  3. Replies: 15
    Last Post: 02-16-2018, 10:44 PM
  4. Replies: 3
    Last Post: 10-10-2016, 03:59 AM
  5. Cruze RPO codes?
    By lostjuan in forum Gen1 Powertrain
    Last Post: 01-12-2016, 03:32 AM
