Rough idle, rough acceleration - No MIL codes. - Page 2
Results 11 to 15 of 15
Thread: Rough idle, rough acceleration - No MIL codes.
    Apr 2013
    Arlington, TX
    28
    No corrosion that I can see here. Though if I knew how this thing was wired up, could check primary and secondary winding resistance in the coil. See if there's a spec, or if they are at least consistent across the pack.
    2012 Cruze 1LT RS
    1989 Taurus SHO
    Apr 2013
    Arlington, TX
    28
    Just as a follow up here, I wound up changing the plugs to NGK BKR7E plugs. All of the stumble and surging I was having is completely gone. Will see how it holds up over time, But very pleased so far.
    2012 Cruze 1LT RS
    1989 Taurus SHO
    cufarmer is offline [OP]
    Oct 2014
    Spring, TX
    73
    I am still working on the problem with the ignition coil. I have swapped out plugs but the number 3 cylinder consistently misses.
    1st Gear neirfin's Avatar
    270
    Quote Originally Posted by cufarmer View Post
    did you make sure the springs inside the coil boots aren't caught up on the rubber? when I changed my plugs I noticed 2 of them were caught on the boot, may have been keeping them from making solid contact with the plugs. something to check for anyways.
    Jan 2019
    8
    I have a 2014 Cruze, 1.4L Eco and I have the exact same problem.
    Idle is smooth, but very poor and jerky acceleration, especially between 2 and 3k on the tach. Also noticing an engine/oil/exhaust smell when stopped.
    If I manually down shift and get the revs high, then I have some acceleration power, but it is still weak.
    I also have the cylinder 3 misfire, according to the computer, but no codes.
    I replaced the #3 plug spring, plug boot, and spark plug, but I still have the problem.
    I am going to replace the coil pack next, as the only visual clue I have seen was some dirtiness on the top of the original #3 plug spring, and inside the #3 coil pack barrel.
    Might be #3 fuel injector, so that is also on my hit list.
  8. Remove Advertisements
  1. Rough idle at times
    By Speedy McD in forum Gen1 Service Issues
    Last Post: 08-21-2018, 12:00 PM
  2. Rough idle issues
    By TopazRS87 in forum Gen1 1.4L Turbo
    Last Post: 06-20-2014, 10:26 PM
  3. Rough idle at stop
    By kylake in forum Gen1 1.4L Turbo
    Last Post: 08-21-2013, 07:44 PM
  4. Rough Idle Issue
    By Rapp in forum Gen1 1.4L Turbo
    Last Post: 02-24-2013, 06:40 PM
  5. Slightly Rough Idle
    By JGA in forum Gen1 Powertrain
    Last Post: 04-30-2011, 05:30 PM
