Oil cooler leak - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 37
Like Tree5Likes
Thread: Oil cooler leak
  1. #21
    So Cal
    49
    I probably should have replaced the oil return for the turbo as well for another $20. Might still do it. Are you aware of how much oil loss there is in replacing that part as I just did an oil change?
  3. #22
    Aug 2014
    183
    Quote Originally Posted by Rapp View Post
    You all are getting way above my pay grade with fabricating your own parts :-o
    Hehe.. actually my Cruze has two self machined parts so far..
  4. #23
    Jan 2013
    N/W Indiana
    325
    I can only guess you'll only lose what is in the turbo housing itself. Not much at all I would assume.
  6. #24
    Apr 2013
    22
    Hi All,
    Do all of you remove exhaust intake and turbo for this job? I looked up this job in shop manual and it shows that only catalytic converter needs to be removed. Of course removing turbo would give you more room but is it neccessary? Removing turbo+intake requires new gaskets, bolts … and possibly of breaking plastic oil lines etc.
    Did any of you did this job by just removing catalytic converter as per shop manual?
    Thanks!
  7. #25
    May 2016
    Grand Blanc, MI
    177
    Haven't replaced myself. But, if you're under powertrain warranty still, the line is covered.
    Quote Originally Posted by OEMplusCC View Post
    Hi All,
    Thanks!
  8. #26
    235
    Hi All,
    Thanks!
    I just finished this job , and the shop manual is correct. You do not have to remove the turbo/exhaust manifold. However, I chose to since it is a lot easier and you can access everything from the top instead of the bottom. I also replaced a lot of other gaskets while I was in there like oil pan, o-rings, etc.
    If you choose to remove the turbo, get a spare oil drain tube on hand. They are plastic, get incredibly brittle with age, and take almost zero flexing before they crack.
    2012 Cruze Eco MT
  9. #27
    Apr 2013
    22
    Quote Originally Posted by lonewolf04 View Post
    Unfortunately my powertrian warranty expired this year so I will be doing it myself. My oil pan seal was leaking beginning this year and GM covered it.
    Quote Originally Posted by MyShibbyEco View Post
    Thanks for the response, I think I'll just try doing it with the turbo on. If it becomes impossible then Ill order rest of the parts and remove it.
    One more question since you just did it.
    How do you remove the pipe that attaches to the left of the oil cooler. To be clear, the pipe that attaches to the left to that "ribbed box" aka heat ex-changer.
    Here is a picture from internet for illustration (notice the shiny inlet on the left)
    Do you pull/push the pipe? Or do you twist it somehow? Or is there some security tab? Shop manual has no detail on that.
    Thanks!
  10. #28
    235
    <img>
    Thanks!
    It's an o-ring pushed straight into the opening. You'll remove the rubber end clamped on the left side of the pipe, and the one bolt in the middle holding it down, then pull straight out. The oil cooler housing also has an o-ring insert going into the engine block so you'll pull the cooler slightly out and up. Be gentle on the turbo coolant pipe that crosses in front of the cooler (it has a bolt holding it to the cooler). Do not try to bend it out of the way or it will start leaking at the quick connect at the turbo side.
    If you decide to remove the turbo, order new turbo coolant pipes and quick fittings as well. The quick fittings have terrible seals on the inside and any slight side-to-side movement will permanently ruin it. They're expensive for what they are, but you may get things back together just to find one or both of those leaking (speaking from experience).
    It also helps to apply some plumbing silicone grease to the o-rings when installing everything. Makes the o-rings slide together and prevents binding.
    2012 Cruze Eco MT
  11. #29
    BOOOOST!
    1,275
    Following this thread for OEMPlus if you do it without ending up pulling the turbo, please let us know and any tips we should try. Based on what I researched when reading alldata the engine thing might slide out towards the drivers side once everything is loose.
    Disconnecting the hose at the thermostat with remote access hose clamp pliers, and bolts under neigh. I'm smelling burning oil, I have a feeling the intake manifold PCV job and this oil cooler job might be on my task list come spring if I have plans on long term keeping the car.
    2012 Cruze LT, 1.4L, AT 78,000 Miles as of 1/19
    Looking for EV for next car.. Bolt or maybe Model 3 if Chevy doesn't speed up their EV's to the marketplace!
    Previous Rides
    2002 Intrigue 3.5L,LX5, AT 135,000- Owned for 10 years.. PM for Intrigue help. P1811 also a problem with this car.
    2000 Intrigue 3.5L, LX5, AT, 89,000- Owned for 12 years.. Dreaded P1811 killed this transmission.
  12. #30
    Learning about my Cruze Thebigzeus's Avatar
    Dec 2018
    Austin, TX
    88
    Thanks!
    So... how did it go without removing everything?
  1. Engine oil cooler replacement?
    By snowvette in forum Gen1 1.4L Turbo
    Last Post: 08-07-2018, 03:31 AM
  2. Transmission Oil Cooler
    By bsb2001ca in forum Gen1 Powertrain
    Last Post: 08-06-2018, 04:11 PM
  3. Engine Oil Cooler leaking
    By googenfrog in forum CruzeTalk New Member Introductions
    Last Post: 02-18-2016, 05:40 AM
  4. Oil cooler
    By jimmyboy in forum Gen1 1.4L Turbo
    Last Post: 01-22-2016, 12:28 PM
  5. HELP! Engine Oil Leak / Tranmission Cooling Line Leak
    By ty367 in forum General Discussion
    Last Post: 03-22-2015, 12:31 PM
