2011-2016 Cruze 1.4 PCV Valve Cover/Intake Manifold Issues - Page 23
Page 23 of 25 FirstFirst ... 13 21 22 23 24 25 LastLast
Results 221 to 230 of 244
Like Tree60Likes
Thread: 2011-2016 Cruze 1.4 PCV Valve Cover/Intake Manifold Issues
  1. #221
    Jun 2016
    OH
    50
    Quote Originally Posted by ownerof2011cruze View Post
    New intake manifold removal video on youtube
    https://youtu.be/CRY62-mc_zI
    i've done this before - but thanks for posting this. should come in handy for future reference in this thread!
    2014 Silverado
    2014 Cruze
    1999 Trans AM
    1998 Formula
    1989 TTA
  3. #222
    Driver's Ed 6rout's Avatar
    Feb 2019
    14
    Bought a 2015 2LT last weekend, within 2 days there was burning smell in the cabin and a bunch of oil leakage from the crankcase. Dealership replaced the valve cover and an o-ring in the oil filler. I looked at the PCV system this morning and found the check valve was also missing. I'm taking it to a nearby Chevy dealer this week, who I expect to replace the intake manifold under warranty, knowing it will probably fail again in the future. Is there a general estimated lifespan for a new installation of this valve? It's out of warranty next year, and after it goes again I'll probably put in the fix kit.
  4. #223
    Feb 2019
    14
    Just replaced my PCV hose with the AC Delco part. The hose was very fouled with oil and not only was the valve failed, I discovered someone had previously made this expert repair on the old one:
    the hose was cut, an inch-long segment of rubber tubing inserted between the two sections, and the whole thing was wrapped up with black tape.
  6. #224
    Apr 2019
    I had my intake manifold and valve cover replaced when I was under warranty but now that I'm 60k over 100k it's whistling again. It's sucking in air at the diaphragm and I'm missing the orange nipple. Do I need the kit (which I already ordered) and the new valve cover?thanks.
  7. #225
    15,550
    Quote Originally Posted by digiSal View Post
    I would definitely replace the valve cover and install the kit. The valve cover is what failed first. The intake manifold isn't far behind if it hasn't already failed.
    Sent from my BlackBerry Key2 using Tapatalk
    Link::Hidden Content
  8. #226
    Apr 2019
    Thank you. I've ordered the kit and the valve cover. Anything we can do to prevent the valve cover from going bad? Will the kit help?
  9. #227
    May 2019
    1
    Xtreme, thank you for your expertise and all of the information you post on this subject. I had the same issues; check engine light, running bad, oil in places it shouldn't be, etc. I quickly found the bad valve cover diaphragm and then the missing check valve in the manifold. I'm new to this forum and started reading a lot of info on here in search of a permanent solution.
    If I wasn't in a rush to get this fixed, I would have ordered your kit but couldn't wait for shipping. So, I was able to re-create it, more or less based on the info you have made public. I ordered check valve from McMaster Carr and got the next day and got to work. A few trips to Ace Hardware for fittings and I was in business. I replaced the valve cover and with the manifold mod, the car is running great and no check engine lights.
    I tapped into the Evap/purge connector rather than the brake booster because it was just easier (seemed easier at the time anyway) with what I had to work with.
  10. #228
    May 2014
    Columbus, Ohio
    78
    Does this apply to non turbo engines? My car started throwing codes, PCV, knock sensor and cylinder 4 misfire. Took care of all three things and got the knock sensor code again. Car runs like crap, engine ticks and hesitates when accelerating.
  11. #229
    16,332
    Quote Originally Posted by karna68 View Post
    What model do you have? The LT/Eco/LTZ have the 1.4 turbo; the hydraulic lash adjusters have been known to fail, throw knock sensor codes, and make a ton of noise.
  12. #230
    May 2014
    Columbus, Ohio
    78
    2014 LT, any tips on how to fix?
  1. GM 1.4L Turbo Intake Manifold PCV Valve Fix Kits
    By XtremeRevolution in forum Gen1 1.4L Turbo
    Last Post: 06-19-2019, 06:37 PM
  2. How-To: Remove 2011-2016 Cruze 1.4L Intake Manifold
    By XtremeRevolution in forum Gen1 Engine/Transmission Tutorials
    Last Post: 04-22-2019, 03:42 AM
  3. 2012 1.4T valve cover/pcv recall
    By dirt dauber in forum Gen1 Service Issues
    Last Post: 08-30-2018, 02:14 PM
  4. More PCV and valve cover goodness
    By titan2782 in forum Gen1 1.4L Turbo
    Last Post: 10-23-2016, 10:08 PM
  5. Valve cover woes and PCV
    By flyingvee in forum Gen1 1.4L Turbo
    Last Post: 02-11-2016, 04:06 PM
