2012 ltz cel - Page 2
Results 11 to 20 of 26
Like Tree23Likes
Thread: 2012 ltz cel
    16,332
    Quote Originally Posted by BrandoFisher117 View Post
    Ok, just got the code.
    P0171 - System Too Lean (Bank 1)
    Pcv. See if the disc is hissing. If so, plan on replacing the valve cover
    Sent from my SM-G950U using Tapatalk
    DesPlaines Il
    5,485
    With the possibility of a intake manifold for blown out check valve as well.
    Rob
    6th Gear
    BrandoFisher117's Avatar
    Mar 2016
    Northwest Ohio
    1,228
    Will do. Thank you for the responses! I will keep you all posted on what is happening.
    Sunline Fan likes this.
    BB-8 - 2012 LTZ RS - Silver Ice Metallic
    -VG Shark Fin Antenna
    Driver's Ed Chinashopbull87's Avatar
    Feb 2018
    22
    valve cover !
    6th Gear
    Mar 2016
    Northwest Ohio
    1,228
    Quick update (as it appears I have forgotten...) valve cover ordered, should be here either tomorrow or Friday at the latest.
    Just a side note, I had to fill up the gas tank and after I was done, when I went to start the car, it seems as if it was having a hard time starting. I have the push to start system and when I actually go to start, it will crank longer (and harder) before it actually starts than normal start in the morning/after work. Is this normal with a bad valve cover?
    16,332
    No. That's usually an indication of a failed EVAP purge valve (canister thing on top of the intake manifold)
    6th Gear
    Mar 2016
    Northwest Ohio
    1,228
    Alrighty, thanks J
    6th Gear
    Mar 2016
    Northwest Ohio
    1,228
    Are the EVAP purge valves easy to replace? The site's search function is still acting funny and I'm at work.
    16,332
    Very. Unplug the connector and hoses, pop in the new one.
    DesPlaines Il
    5,485
    Hold off on further part replacement till the vacuum problem is resolved......a vacuum disruption makes all sorts of mayhem.
    Rob
  1. 2012 LS P0597 CEL. Still covered under powertrain?
    By JohnnyV in forum Gen1 Service Issues
    Last Post: 10-14-2016, 01:15 PM
  2. My 2012 LTZ is Overheating!!!
    By BigNorm4Life in forum Gen1 1.4L Turbo
    Last Post: 10-06-2014, 03:22 PM
  3. New Member with a 2012 LTZ
    By FishyLTZ in forum CruzeTalk New Member Introductions
    Last Post: 03-03-2014, 10:27 PM
  4. 2012 LTZ Used
    By cruzering in forum General Discussion
    Last Post: 01-10-2013, 03:58 PM
  5. 2012 LTZ came in wrong
    By Kartoon in forum General Discussion
    Last Post: 09-10-2011, 08:57 PM
