Major oil leak.....Help. - Page 2
Results 11 to 13 of 13
Thread: Major oil leak.....Help.
    May 2016
    Grand Blanc, MI
    177
    Quote Originally Posted by williscu View Post
    Everybody keep going @pe$hit talking about this check nipple. Check your oil cap. If its the small flat one (if its a 2011 it probably is) theres an updated cap with a baffle in it that keeps oil from getting churned up. As an added bonus it seals alot better & I have been boosting better with the updated cap. Oil can travel around the valve cover on the lip where it seals.
    ACDelco FC256 GM Original Equipment Engine Oil Filler Cap - Amazon $20
    That revised cap was because people were not securing the cap level when it went directly to the valve cover. Now there is an extension that comes with the cap. Again, this has nothing to do with excess PCV pressure.
    Jul 2018
    7
    all cars with rubber gaskets leak eventually, its part of planed maintenance/failure.
    Yank is offline [OP]
    Feb 2019
    5
    Thanks for the help everyone. Root cause was the valve cover. Since I need the car back in service and the check valve was still in the intake and I hadn't received the PCV kit yet I went ahead and put it back together with a new valve cover. All the oil leaks are gone. I'll keep an eye on the intake check valve and when it finally let's go I'll go ahead and install the kit. Thanks again.
  1. new oil leak. rear main seal or oil pan ?
    By CruzeEcoBlueTopaz in forum Gen1 1.4L Turbo
    Last Post: 05-12-2018, 02:00 PM
  2. Oil Leak from Turbo Oil Feed Pipe
    By CapitalTruck in forum Gen1 Service Issues
    Last Post: 08-04-2017, 05:21 PM
  3. Help: New Tires = Major Instability and Swaying in the Rear
    By dishwab in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 01-02-2016, 04:10 PM
  4. HELP! Engine Oil Leak / Tranmission Cooling Line Leak
    By ty367 in forum General Discussion
    Last Post: 03-22-2015, 12:31 PM
  5. Major help needed! Emergency brake misuse help
    By wesmonnette in forum General Discussion
    Last Post: 03-12-2014, 06:33 PM
