2012 Cruze LT 1.4l Turbo P0299 Code and Replacement
Results 1 to 6 of 6
Thread: 2012 Cruze LT 1.4l Turbo P0299 Code and Replacement
    MurphNY is offline [OP]
    May 2015
    I have reset and every time the check engine light comes on. States P0299 code pending.
    Approx 183,000 miles on it. I still have the original turbo and replaced the oil feed line 2 weeks ago.
    I have some questions for everyone:
    Is there something else that may fix the issue besides replacing the turbo?
    Does it matter what brand turbo I get?
    Is this something that a backyard mechanic can do or should I have the dealer do this with my part?
    My issue is that it does not lag, I just need to pass NY inspection.
    Thank you for your help.
    5,778
    Quote Originally Posted by MurphNY View Post
    Welcome Aboard!
    Potential causes of a P0299 turbo underboost code include:
    Intake (induction) air restriction or leak
    Failed or damaged turbocharger (sticking, binding, etc.)
    Faulty boost/charge pressure sensor
    Read more at: https://www.obd-codes.com/p0299
    Don't forget to introduce yourself and your Cruze here.
    May 2015
    Thank you for the information. I will be testing the system before I do anything further.
    mjb
    mjb is offline
    May 2018
    New Lenox, IL
    33
    After checking for boost leaks, drop the catalytic converter and check turbo housing for cracks. I had the crack and received the same code. I think you are fine with replacing with GM turbo. Job is not bad at all, but you probably will want to replace the rubber coolant hoses and seals and oil return line if original. Definitely need a good day and gallon of coolant 5 quarts of oil and filter. I think it ran me about $475 total vs quotes at 1800 to 2200. I can send you part number if you need them. send me a pm.
    Follow this thread too.
    https://www.cruzetalk.com/forum/9-ge...ml#post3222343
    May 2015
    Testing revealed the big hose going to the drivers side of the radiator where it meets the boost system was leaking. I tightened the clamp but it came back this morning. I'm off to get a new clamp and hopefully an inspection.
    5,778
    GM 1.4L Turbo Boost & Coolant Leak Testing Kits
  9. Remove Advertisements
  1. loss of power and code P0299
    By metalhdmatt in forum Gen1 Service Issues
    Last Post: 01-03-2019, 04:19 PM
  2. 2012 Cruze LTZ 1.4 liter Turbo engine code P0299
    By Acvanraden in forum Gen1 Service Issues
    Last Post: 10-03-2018, 10:04 AM
  3. 2012 1.4T P0299 and P0599. Thermostat? New turbo?
    By royce777 in forum Gen1 Powertrain
    Last Post: 11-20-2017, 11:44 AM
  4. P0299 code - salvage turbo?
    By Farmerboy in forum Gen1 Service Issues
    Last Post: 08-14-2016, 07:59 PM
  5. Intake Manifold Replacement after P0299 code?
    By raz in forum CruzeTalk New Member Introductions
    Last Post: 10-31-2014, 02:00 PM
