Check engine light/ monitors incomplete
Results 1 to 5 of 5
  • 1 Post By panos7
Thread: Check engine light/ monitors incomplete
    Adnilre1 is offline [OP]
    Apr 2019
    1
    Check engine light on. Code p01101(MAF) cHECK ENGINE LIGHT RESETS ON ITS OWN ONCE IN A WHILE. Replaced MAF sensor and air filter. Cleared code with code reader. Same problem. PCV checks ok and can't find any vacuum leaks using carb cleaner. Engine runs fine but after a few drive cycles after resetting code, I'm still getting 2 incompletes on the monitors. Oxygen sensor heater and evap system. Purge solenoid is good and gas level is half tank. wiring connector on MAF sensor also appears to be okay. Any ideas what is causing code intermitantly and incomplete sensors?
    Drag Racing Champion
    Nov 2017
    1,666
    YOu'll probably have to wait for the code to reappear. The monitors won't complete if there's codes.
    Course, you may not have reached the reset procedure either or there could be other issues.
    Used to be 60 miles driving was required to reset. Not sure what it is these days.
    Sep 2017
    Antelope Valley, CA
    105
    Quote Originally Posted by snowwy66 View Post
    Daughter drove about 60 - (probably closer to) 80 miles yesterday, after we replaced the valve cover on our ECO, before she noticed the CEL turned itself off.
    Chris
    2014 Cruze Eco - Limo-tint (back doors, rear window, & top of windshield), blacked out bowties
    May 2014
    Nuremberg, Germany
    29
    Do you have a cold air intake?
    If yes, than you need to have an air straghtener before the maf, otherwise many aftermarket air intakes will cause P1101 to appear and make your MAF have crazy readings.If you dont than most probably you have a leak somewhere in the intake tract....check all the plumbinmg and the pcv system to rule those out.
    How are your fuel trims? They're a good indication...
    Blasirl likes this.
    5,432
    Quote Originally Posted by Adnilre1 View Post
    Welcome Aboard!
    Don't forget to introduce yourself and your Cruze here.
  8. Remove Advertisements
  1. Replies: 4
    Last Post: 08-10-2017, 05:40 PM
  2. Replies: 10
    Last Post: 03-23-2017, 11:43 PM
  3. Check engine light on, TCS/Stabili track light
    By Dandersen110 in forum Gen1 Service Issues
    Last Post: 08-21-2015, 11:02 AM
  4. Replies: 6
    Last Post: 10-26-2013, 02:43 PM
  5. Check engine light and "airbag service" light after sub install
    By Bammeh in forum Gen1 Audio & Electronics
    Last Post: 05-04-2012, 02:24 PM
