Valve cover air leak AGAIN - Page 5
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 42 of 42
Like Tree5Likes
Thread: Valve cover air leak AGAIN
  1. #41
    May 2019
    1
    My 2014 Chevrolet Cruze had a cracked valve/cam cover at 60K miles. Just got it fixed at the dealer. They replaced the PCV Check Valve and crank seal.
    Symptoms:
    Loud squeaking from serpentine belt area (I actually thought it was a loose pulley)
    Squeaking went away when away when accelerating, but increased when braking and idling
    Rough idling at stoplights
    Check Engine light went on along with "Service Traction Control" and "Service StabilTrak"
    5-8% reduced fuel economy
    One day the fan did not turn off for a full 2 minutes after turning engine off (in 50 degree weather)
    Cost me $500 to get fixed at the dealer (3 hours x $124 + $105 parts + $25 shop charge) as I was outside the 5 year powertrain warranty. Dealer said this is an issue with many Cruzes and to save my receipt in case GM issues a recall.
  3. #42
    5,481
    Quote Originally Posted by Kevin6:33 View Post
    Symptoms:
    Welcome Aboard!
    Things to look at and keep in the back of your head for now:
    Special Coverage #14311: Negative Battery Cable
    2011-2016 Cruze 1.4 PCV Valve Cover/Intake Manifold Issues
    New Thermostat Failing or Sensor or Other?
  4. Remove Advertisements
  1. More PCV and valve cover goodness
    By titan2782 in forum Gen1 1.4L Turbo
    Last Post: 10-23-2016, 10:08 PM
  2. Valve cover leak :D
    By pntballer925 in forum Gen1 1.8L
    Last Post: 10-27-2015, 04:07 PM
  3. Cruze valve cover gasket replaced
    By kylevh21 in forum Gen1 Service Issues
    Last Post: 11-17-2014, 02:15 PM
  4. Valve Cover
    By Jbet in forum Gen1 Service Issues
    Last Post: 10-09-2014, 06:56 PM
  5. Removing the valve cover
    Last Post: 09-18-2013, 12:34 PM
