Help check engine light and rough running
Results 1 to 10 of 19
Like Tree2Likes
Thread: Help check engine light and rough running
    Jul 2014
    Chester County PA
    73
    So out of the blue today my car while sitting started to almost chug and try to jump forward and now its running rough and making the almost crunch noise any ideas what it is I have a video but won't let me post it through my phone ill post it up as soon as I can
    WARNING: DO NOT TRY WHAT YOU ARE ABOUT TO READ AT HOME. I AM AN UNTRAINED NON-PROFESSIONAL MAN CHILD WITH ZERO ADULT SUPERVISION.
    Jul 2014
    Chester County PA
    73
    Heres the video Chevy cruze 1.4 rough running mystery sound: http://youtu.be/WrEbeWG1ca0
    Jul 2013
    213
    Even though the video is poor quality that is what mine sounded like when the fly wheel went.
    Touring Champion money_man's Avatar
    Feb 2014
    Halifax, Nova Scotia
    3,340
    Normally a cracked flywheel will make a ting ting ting sound. That sounds like something let go in the engine. Still have any warranty?
    2014 cruze diesel 2.0TD
    2009 Ford escape limited v6 4x4
    1971 Nova SS 406ci TH350w/shift kit
    Jul 2014
    Chester County PA
    73
    Yeah its still under warranty I haven't even had it a month sounds like its all coming from under the valve cover
    spacedout's Avatar
    SW Wisconsin
    6,920
    Sounds like your PCV is bad, anyone else notice the vacuum leak/air suck sound from the valve cover when he removed the cover at the end of video? You can also see you have the original valve cover design(https://www.cruzetalk.com/forum/129-e...-4l-turbo.html).
    Did you check the codes to see what codes are stored? that will help diagnose the problem. Pretty sure others have mentioned on here that when the PCV is blocked the motor struggles trying to idle(how yours sounds).
    Feb 2014
    3,340
    I'd just take it back to the dealership to fix it. That's what warranties are for
    Retired Moderator CHEVYCRUZE RS's Avatar
    Toronto, Canada
    2,856
    what was the engine code it sent you? if you had a tool to check
    ZZPerformance.com
    Rotiform.com
    1983 Fiat 124 Spyder
    1990 Corvette C4 ZR1
    2018 Chevy Silverado LTZ Z71
    2011 Chevy Cruze LTZ RS
    2009 Chevy Savanna 1500
    2018 BMW 328x Diesel
    DesPlaines Il
    5,454
    Yep, spacedout is on it....needs a valve cover for the leaking pcv.
    The vacuum hiss is the clue.
    Sounds all kinds of broken but it is just the computer going insane trying to get the fuel mixture right.
    Basic repair.
    Rob
    spacedout likes this.
    Jul 2014
    Chester County PA
    73
    That's what I kind of figured but the noise of it is what freaked me out here's a better video Cruze 1.4 auto mystery sound 2: http://youtu.be/tUdVMkwTv2A
  1. Check Engine Light after replacing Engine Harness
    By e_mata06 in forum Gen1 Service Issues
    Last Post: 10-28-2013, 05:29 PM
  2. Replies: 6
    Last Post: 10-26-2013, 02:43 PM
  3. Coolant leak, engine light, and rough idle
    By aferrell71 in forum Gen1 1.4L Turbo
    Last Post: 10-02-2013, 12:37 PM
  4. check engine light on, engine feels hot but gauge normal
    By psumner1 in forum CruzeTalk New Member Introductions
    Last Post: 09-13-2013, 03:30 PM
  5. LS manual rough engine check light stabilitrack issues on start up
    By Ajax Inferno in forum Gen1 Service Issues
    Last Post: 11-06-2011, 08:37 PM
