Cruze not starting and smells Rich
Results 1 to 6 of 6
Thread: Cruze not starting and smells Rich
    jmaawhaley is offline [OP]
    Apr 2019
    Hi All:
    Forgive me if this has been asked, but I searched and could not find anything similar...
    2013 Cruze 1.8L with just over 90000 miles. Tries to start but can't and it smells very rich. It was starting not long ago, but would idle rough and then act like it ran out of gas with no CEL. I have changed the fuel pump, Mass Air Sensor and valve cover (PCV built in) with no luck...
    Can anyone else think of anything to try before I take it somewhere? Any information is greatly appreciated. Thanks in advance.
    Learning about my Cruze Thebigzeus's Avatar
    Dec 2018
    Austin, TX
    89
    Well an engine needs 3 things to run... air, fuel, and spark. Sound like you may have one of them checked off if it smells rich. I'd concentrate on the other two and see where you end up. Do you have spark? Will it start with starting fluid?
    5,513
    Quote Originally Posted by jmaawhaley View Post
    Hi All:
    Welcome Aboard!
    After you figure out what is wrong with the Cruze, don't forget to intoduce yourself and your Cruze here.
    Make sure the fuel pump solenoid is working. Open the hood and the drivers window. Reach in and turn the key on - do not crank - and listen for two things. The relay under the hood click on for a few seconds and then back off. Now, when doing that, listen for the fuel pump. It should run when the relay control circut is active.
    If those things are good, make sure your fuel filter is also good.
    If all is well so far, have a look at this. It is for a 1.4 but I would think the basic operation is very similar. This is abit above me, but I figured, why not.
    The next thing to look at is spark.
    Apr 2019
    Thanks for the welcome! So here is an update - I unhooked the battery and let it sit overnight. Woke up this morning, hooked the battery back up and it started again. Ran very rough, but it did start and had a CEL now. Still had an extreme rich smell. On the way home from work, stopped by parts store and rented an OBD-II reader and found a P0300 code, No other codes. Took off the coil pack assembly and took the plugs out. They were black. Cleaned them up, put them back in, and fired it up. It ran decent for a few minutes but then started to miss again and eventually die. I had just changed the plugs a few months back (along with timing belt, serpentine belt and water pump). Could it be the coil pack assembly? Do they slowly go bad or do they either work / not work? Or, I was reading about vacuum leaks also... Again any suggestions are greatly appreciated. Thanks.
    16,265
    Coil packs fail left and right on these cars, but usually not like this. I would hold off on that. It sounds like something is causing it just to dump gas.
    Do you still have the old MAF? Swap that in and give it a try.
    Does your OBD tool happen to show what the coolant temp sensor thinks the temperature is? I have seen these fail and cause an extremely hard, rich start. Haven't seen this on a Cruze specifically, but the coolant temp sensors have been known to go bad as well. How about the outside temp display on the radio - is that accurate?
    FYI, holding the gas pedal to the floor in GM cars enters a "flood clear" mode that shuts off the injectors and holds the throttle plate open. Might help you get it going if it smells super rich again.
    5,513
    A code P0300 may mean that one or more of the following has happened:
    Faulty spark plugs or wires
    Faulty coil (pack)
    Faulty oxygen sensor(s)
    Faulty fuel injector(s)
    Burned exhaust valve
    Faulty catalytic converter(s)
    Stuck/blocked/leaking EGR valve / passages
    Faulty camshaft position sensor
    Defective computer
    Read more at: https://www.obd-codes.com/p0300
  9. Remove Advertisements
  1. A new Cruze - Starting the fan without starting the ac
    By yoramcruze in forum General Discussion
    Last Post: 12-05-2018, 08:27 PM
  2. Replies: 19
    Last Post: 11-12-2018, 10:22 AM
  3. 2014 Cruze Outside smells from ac
    By Mohsafadi in forum Gen1 Service Issues
    Last Post: 04-09-2017, 04:24 PM
  4. Rich + Cruze in Phoenix
    By Rich+Cruze! in forum CruzeTalk New Member Introductions
    Last Post: 04-13-2014, 08:06 PM
  5. Running rich? (soot on tailpipe/rearbumper)
    By oolowrideoo in forum Gen1 1.4L Turbo
    Last Post: 11-10-2011, 02:34 AM
