The SQ Car Audio Thread V2 - Page 47
Page 47 of 47 FirstFirst ... 37 45 46 47
Results 461 to 469 of 469
Like Tree97Likes
Thread: The SQ Car Audio Thread V2
  1. #461
    Nov 2016
    96
    Looking at different amplifier options, what affect will it have on the front stage if we used a lower wattage rating amp, say 20-30 watts rms for the tweets, and a higher rated amp on the silverflutes? Would this need to be adjusted for in the DSP Tune?
    I understand the tweets don't need a lot of power. What is the RMS rating on the silver flutes? All I can find listed is 80 watts but that doesn't specify RMS or MAX.
  3. #462
    15,543
    No effect at all. I used a 25W per channel coustic power logic amp (made in 1992) for a while on my tweeters and they were fine. No adjustment needed.
    RMS on the silver flutes is probably around 50W.
    Sent from my BlackBerry PRIV using Tapatalk
    Link::Hidden Content
  4. #463
    Oct 2013
    Middle east
    100
    I'm starting to think that the Factory headunit doesn't give out enough Volt to even consider adding an Aftermarket amp or Speakers, I've gone that route and my Sound quality at moderate to high volumes has dropped significantly. All I'm hearing is High pitched sounds from tweeter and somewhat low quality thin sounding Mids from the woofers.
    The technician said its mostly my Factory Headunit, which is underpowered for such setup. Adding an amp , speakers and sub has done very little to change the SQ.
    I've also created a new thread and would like someone to help me here: https://www.cruzetalk.com/forum/36-ge...akers-sub.html
  6. #464
    Nov 2016
    96
    For those of you that used the mini DC isolator, how did you physically mount it? Make a box or housing for it or just wrap in something like electrical tape? I don't see a housing available for purchase for it.
  7. #465
    May 2014
    Louisville, CO
    12
  8. #466
    Nov 2016
    96
    I purchased something similar.
    Here are 2 pictures of it mounted in the box and the box mounted to the dash's metal frame behind the glove box. The lid is not installed in these pictures. It has a snap on lid/cover.
  9. #467
    Nov 2016
    96
    SCruze
    I began to think the same thing about the stock head unit. I installed everything and triple checked all my wiring. Sounded like crap. Messed with the amp gains and swapping cables. Nothing improved the sound. Turning the volume up just sounded horrible. I mean really bad. What I came to find out was that I made a huge error. I thought I installed the tune file into the DSP when in actuality I didn't. I got the message from the software stating the file loaded successfully. When I got this message I assumed it was installed on the minidsp. I read through the manual a little more carefully and found my error. Consequently I damaged a Tweeter in the process. Once sorted out it sounds pretty good. Plenty of power and clarity. This may have been your issue as well???? I find the DSP stuff to be very confusing.
    Sent from my Z717VL using Tapatalk
  10. #468
    Nov 2016
    96
    I'm up to 104 hours of install time, got my DSP issues sorted out, Sub installed, gains all adjusted, interior mostly back together and I finally got to really listen to it. Well, all I can say is, Amazing. Yes, it's that good. Thank you very much MR. Xtreme. All that is left is to finish up all the sound deadening and mount the amp shelf under the rear deck. I'm stoked. I can safely drive it now that most of it is back together. Probably another 50 hours or so should do it. This has been a huge job and the end result is well worth it.
    Rich.
    XtremeRevolution likes this.
  11. #469
    Apr 2019
    Melbourne, Australia
    15
    What a great thread even tho its quite old now but stills seems relevant to Gen 1 cars. I actually have a 2018 Holden Astra Sedan down in Melbourne Australia but its a rebadged Chevy Cruze.....its the 6 speaker setup...non-amplified so have the dash, front, and rear doors.
    Is there anything setup like this for Gen 2 cars or are they close enough to each other that this will work fine for a Gen 2 car?
    Shipping things to Australia is another matter but one problem at a time
    Thanks!
  1. The Car Audio SQ "How-To" Thread
    By XtremeRevolution in forum Gen1 Audio/Electrical Tutorials
    Last Post: 11-26-2016, 02:13 PM
  2. Audio Setup in car.
    By APCruze in forum General Discussion
    Last Post: 07-14-2013, 06:53 PM
  3. Car audio guys, how do you do it?
    By sciphi in forum Off Topic Discussion
    Last Post: 04-01-2013, 04:42 PM
  4. Audio build thread
    By patatewz in forum Gen1 Audio & Electronics
    Last Post: 10-07-2012, 08:32 PM
  5. Yet another audio thread
    By Beachernaut in forum Gen1 Audio & Electronics
    Last Post: 04-16-2012, 03:14 PM
