2018 HB Steering Squeak
Results 1 to 6 of 6
Thread: 2018 HB Steering Squeak
    Iamantman is offline [OP]
    Handbrake Released Iamantman's Avatar
    Sep 2018
    119
    Hey everyone,
    Anyone else get an annoying steering squeak when turning the wheel? I thought that was ironed out in the early gen 2s. I have a 2018 with 5000 miles and am experiencing that. I figured the shaft was just dry so last time I was at my garage I lubed up the boot and shaft with white lithium grease and it seemed to help but then came back leading me to think this is a design flaw.
    Maven, you're a current tech right? Do you know of any TSBs about this? I don't wanna have to spray it with wd40 every 1000 miles. That's really silly.
    16,263
    My 16 never did this, but my '12 did once the steering was disconnected to get the transmission out. The plastic bearing thing was sitting too low in the floor passthrough. Hammered it up a bit from below, and it solved that.
    Sep 2018
    119
    Ugh pretty sure this is probably the issue then.
    The full story is I took my car in at about 2000 miles because I had steering noise over bumps which ended up being the sway bar end links. Despite GM engineers telling my dealership how to diagnose the problem and to replace the links, they also changed my sway bar at the time. I used to be a mechanic so at this point I'm basically 99% sure the tech was padding their hours because warranty work pays terribly. I've been there. Problem is they dropped my subframe for that and in the process put my car out of alignment. I was so pissed. I had to go back and when they agreed to fix it the **** tech didn't tighten the lock nuts on the tie rod and by the time I got home it was clunking from play. I tightened them myself and left a very stern email with the dealership manager.
    Sorry that turned into a rant haha. But after hearing you say that I bet they messed something up when they dropped the frame.
    16,263
    Quote Originally Posted by Iamantman View Post
    I also had my tie rods replaced on the 16 for the clunking, but I have avoided the dealer where shoddy warranty work was done on the '12. Sorry; it's super frustrating when you get one of those techs that cuts corners like that and the service department doesn't seem to care.
    Sep 2018
    119
    Hey Blackburn, I meant to follow up to this. We're you able to access the bearing from underneath without a lift or jacks? I'm in the city so if I can't just crawl under there on a dry day and take care of it I'll have to go to the dealer 😕 lubing it isn't cutting it so I'd like to try what you did there.
    Thanks
    16,263
    Thanks
    I have Rhino Ramps I drive the cars up on any time I go under them. I can't get under most low-slung cars these days without.
    It was pretty awkward on the Gen 1 - the steering shaft comes through sorta behind the transmission.
  9. Remove Advertisements
  1. New Member - 2018 Cruze HB Manual Diesel
    By dlmetzger63 in forum CruzeTalk New Member Introductions
    Last Post: 11-14-2017, 11:09 AM
  2. A new 2017 hb owner
    By Sapphiremom in forum CruzeTalk New Member Introductions
    Last Post: 10-14-2017, 07:00 PM
  3. Navigation module in '17 Cruze Premier HB
    By 1kulsol in forum Gen2 Audio & Electronics
    Last Post: 09-15-2017, 03:14 PM
  4. Replies: 7
    Last Post: 03-28-2015, 03:00 PM
  5. Steering wheel squeak fixed!
    By sciphi in forum Gen1 Service Issues
    Last Post: 05-01-2013, 03:01 AM
