$4 Oil Change Ramps
Results 1 to 10 of 12
Like Tree12Likes
Thread: $4 Oil Change Ramps
    Taxman is online now [OP]
    5th Gear
    Taxman's Avatar
    Aug 2017
    Olivet MI USA
    965
    $4 Oil Change Ramps
    Yes, they're low, but you don't have to worry about scraping the air dam driving onto them.
    With the front wheels sitting on these (12" pictured), I have plenty of room to put my huge 4 gallon oil collector under the car, reach in and remove the oil plug and filter (and I'm under 6' and over 200lb).
    And the little bit of lift helps move the oil towards the drain hole at the back of the oil pan.
    12" wide for $4 a pair.
    16" wide for $6 a pair.
    guuyuk and Rivergoer like this.
    2017 Cruze LT RS
    2016 Cruze LT with Sun&Sound
    Drag Racing Champion
    Nov 2017
    1,680
    I have a small 2 ton harborfreight floor jack that works great for oil changes and tire rotations. It's not the greatest but it does the job for $20.
    I"d like to find some small jack stands.
    5th Gear
    Taxman's Avatar
    Aug 2017
    Olivet MI USA
    965
    I think my small jack stands are about 11 1/2" fully lowered.
    If I were doing much more than removing a drain plug I'd want the frame at least that high.
    If I'm replacing brake lines I set them at about 16".
    If I'm doing exhaust work I get out the 26" truck stands.
    Another thing you can do is get some 4x8x16" cap blocks, (or stack some thin pavers 2 or 3 blocks high) raise the car up with a floor jack, and set the wheels on the blocks.
    I'd be leery of sticking my head under a Cruze height car with just a jack.
    If my head got caught between the subframe and the concrete on the bounce, my skull might break.
    I like the pavers for quick and simple jobs when I'm not spending much time under the car.
    It's quicker to toss them in front of the wheels than it is to position the jack, and the car's sitting on solid concrete.
    Rivergoer likes this.
    2017 Cruze LT RS
    Rivergoer's Avatar
    Mar 2017
    Parker, AZ
    2,336
    My cheapo ramps, old 2x8 lumber from a gooseneck trailer bed screwed together...heavy but effective.
    Gradual incline low enough to clear air dam, underbody...raises car about 5 inches.
    guuyuk, Taxman and snowwy66 like this.
    2014 White Cruze Diesel, 3rd Owner, Bought 3/17 With 09 TDI Buyback $$$
    2006 Dodge Ram 3500 Laramie Megacab 4x4 Cummins Dually, 245,000 Miles
    1987 Chevy 3/4 Ton 4x4 Suburban, 383 Stroker, North of 300,000 Miles
    Thank you Veterans!
    5,531
    This is my "lowered" ramps. Made them at the end of summer from scraps of 1x8. Works perfect to get my 4 ton jack under the Bomb.
    Rivergoer, Taxman and snowwy66 like this.
    Nov 2017
    1,680
    I need something higher. My fat A rolls around on a creeper.
    5th Gear
    Taxman's Avatar
    Aug 2017
    Olivet MI USA
    965
    Public service announcement...
    Don't crawl under a vehicle that's parked on these:
    2017 Cruze LT RS
    145
    Quote Originally Posted by Taxman View Post
    Don't crawl under a vehicle that's parked on these: <snip pic>
    I suspect these were already damaged, then broke when they were used. Is that right (do you know)?
    If there's any crack or other damage to one of these plastic ramps (Rhino), they need to be tossed. They don't fail gracefully.
    Doug
    -- Silver 2013 Cruze 1LS
    -- Copper 2012 Cruze 2LS
    Off-Road Champion boraz's Avatar
    Aug 2013
    BC
    2,434
    what happened to your rocker?
    2014 Cruze Diesel - White 140,000 km
    1998 XJ 3" 31" Hakka LT 350,000 km
    1998 XJ 3" 31" Hakka LT 320,000 km
    5,531
    Quote Originally Posted by boraz View Post
    I was backing out of a driveway that had a wooden step that sticks out into the driveway. The drive is two vehicles wide and people park on the side away from the porch (step). I was trying to back out a trailer, concerned with not hitting someone car and since the step is so low, I did not see it, more like I felt it deform the rocker. It could have been really ugly if I were going fast.
    Hopefully this spring it will be fixed.
    boraz likes this.
  1. Runaway Truck Ramps. Didn't know they worked this way?
    By Eddy Cruze in forum Off Topic Discussion
    Last Post: 09-03-2016, 10:48 AM
  2. Who has purchased ramps that will work on the ECO?
    By 99_XC600 in forum General Discussion
    Last Post: 10-17-2013, 08:02 PM
  3. Cruze car ramps, another minor problem.
    By NickD in forum General Discussion
    Last Post: 08-24-2012, 11:28 PM
