Code P0420
Results 1 to 4 of 4
Thread: Code P0420
    Mar 2018
    18
    Code P0420
    P0420
    This is a permanent code cannot be cleared with code reader.
    Will only clear if system decides problem no longer exists.
    I used CRC Intake valve cleaner as directed after one week I re-scanned problem has now gone away.
    My conclusion is that dirty valves were causing said code.
    829
    P0420 is not that type of code. It is able to be cleared with a scan tool.
    It's possible dirty valves could lead to poor running which could poison a cat. But it's not likely. I haven't seen any notably filthy LE2 intake valvetrains yet. Not have I seen an instance where a spray in intake cleaner cured a truly failed cat. It was more likely a fuel related issue that time resolved.
    Mar 2018
    18
    Quote Originally Posted by Ma v e n View Post
    Ok, that's interesting my bluedriver scan tool indicated it was a permanent code?
    You might well be right regarding the fuel, I had just ran some Redline SI 1 complete fuel system cleaner through it and the code threw up shortly afterwards, any thoughts as to why?
    So, the little Cruze egr/valvecover does a pretty good job of "catching" those nasty oils after all. What kind of buildup and at what mileages approx have you observed the valves?
    5,771
    This is a service issue and not a tutorial - moved from Gen II Engine/Trans Tutorials to Gen II Service Issues
  7. Remove Advertisements
  1. P0420 code on 14 model with 1.4
    By fountain in forum General Discussion
    Last Post: 10-16-2018, 10:43 AM
  2. p0420 code after replacing 02 sensors, cat, turbo and plugs
    By royaltea in forum General Discussion
    Last Post: 06-17-2018, 04:35 PM
  3. Replies: 3
    Last Post: 02-26-2018, 10:08 AM
  4. P0420 code problem
    By billym81 in forum Gen1 1.4L Turbo
    Last Post: 11-25-2017, 08:03 PM
  5. Check Engine light- P0420 code
    By fj40intow in forum Gen1 Diesel General Discussion
    Last Post: 01-04-2016, 02:48 AM
