What's this part called?
Results 1 to 10 of 16
Thread: What's this part called?
    Fuhnominon is offline [OP]
    Caribbean
    65
    Hello, does anyone know the name or part number of the part that extends out of the bottom if the Gen 2 Cruze that tblack arrow is pointing to in the attached photo?
    5,521
    Can you insert the picture instead of attaching it. It will not pull up to the larger version for some reason. That said, I cant see it, but if I'm looking at a picture of a dissasembled front end, it is a piece of aerodynamic plastic.
    Caribbean
    65
    Thanks for your help. I haven't a clue how to insert a photo? My apologies but I am a novice
    Mar 2016
    35
    Had the same problem when I tried to attach a photo that I edited by drawing arrow in pic. Some reason it won’t open and says image won’t load. Try using original photo it will load. Would also like to know how to insert pic
    145
    Quote Originally Posted by Drmilr View Post
    If you used Microsoft Paint to edit the pic, it will often make the file size larger when it is saved. It does not compress .jpg files very well, for example. I use a different tool called Gimp, which is freeware. It does a much better job of compressing the files, altho the editor is a bit clunky to drive.
    A quick look here did not turn up the file size limits for attachments, but I'm thinking you may have crossed the threshold for file size when you edited it.
    Also note that, after you browse to a file on your computer, you need to click on the text string "Upload File(s)" below the browse button. It's not obvious at first that you need to do that. The string is not boxed or otherwise highlighted until you drag over it.
    HTH.
    Doug
    -- Silver 2013 Cruze 1LS
    -- Copper 2012 Cruze 2LS
    Caribbean
    65
    Thank you so much for explaining.
    MP81's Avatar
    Washington Township, MI
    3,599
    The pic works fine if you open it in a new window/tab.
    Do you have another image of the part in question - as in, from a different angle?
    Caribbean
    65
    Quote Originally Posted by MP81 View Post
    Thank you for letting me know. I will crop the area and put a better and larger arrow so that you can see it properly. But they are two black pieces sticking out of the sides of the intercooler that seem to mirror the chassis of the vehicle directly to the front of the vehicle under the engine bay.
    Caribbean
    65
    I zoomed in and cropped the photo to allow better view of the part. Can you decided what it is now? Hope it's not too small, the app keeps resizing the photo attachments. Can. You see the crooked thin black arrow pointing to the part?
    MP81's Avatar
    3,599
    If it's metal, it's probably the subframe.
  1. What is this part called?
    By rimes9845 in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 02-16-2016, 10:05 PM
  2. What is this part under the front fender called?
    By Nescafe in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 07-09-2015, 09:19 PM
  3. Called dealer for first service, not impressed.
    By DLORESKI in forum Gen1 Diesel General Discussion
    Last Post: 12-07-2013, 08:43 PM
  4. 19" wheels and windshield or what ever its called
    By GFO_Hoffi in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 03-25-2012, 06:18 AM
