2018 Cruze 1.4 Spark knock continues and slight misfire, no CEL or codes stored
Results 1 to 7 of 7
  • 1 Post By Ma v e n
Thread: 2018 Cruze 1.4 Spark knock continues and slight misfire, no CEL or codes stored
    Driver's Ed BluezCruze2018's Avatar
    Aug 2018
    11
    For the past few months my car has been at the Dealership multiple times for LSPI, Spark knock, and an intermittent misfire (hiccup) under load or when I ease into the throttle on a hill. The dealership had my car for over a month, apparently did all kinds of tests, had a tac case on it too. “Could not duplicate concern at this time” written on repair order #4. As of today, I’m still experiencing Spark knock under load or light acceleration, along with a loud pinging under heavy acceleration. I’ve switched to Mobile 1 synthetic oil, and it doesn’t matter what grade of fuel I use either. The longer I drive the worse it gets. Also I’ve been experiencing rough idle/surging immediately after I refill the car. I don’t top off the fuel tank either and when the pump stops I close the gas cap. Once I restart the car it idles rough and starts surging. Once I put it in gear and drive off, it runs normally after that. What should I do? I’m getting to the point of wanting GM to buy this car back. I’ve got 14,800 miles and it’s been in the shop longer than I’ve owned it.
    770
    There's an updated engine calibration to reduce likelihood of piston damage from LSPI. It typically only gets installed on cars that get pistons, but it may help you if it hasn't been updated yet. Document 5080870 in GM Service Information mentions the availability of the calibration. It's worth asking about.
    Additionally you should check your air filter and make sure it's properly locked in place and it's bracket isn't warped or otherwise damaged.
    16,261
    Your symptoms of a hard start and rough idle after filling up suggest a bad EVAP purge valve - a super common failure on the 1st gen 1.4/1.8.
    Jan 2013
    KDH, NC
    29
    My '18 1.4 stutters and sputters throughout the RPM range during acceleration. I think it's just how they're tuned. It's likely constantly adjusting for ideal fuel economy depending on throttle position, engine and ambient air temperature, fuel quality, load, etc.
    Pretty annoying and it is likely especially pronounced with a manual transmission. But I think it's normal. My '13 Accord 6MT is the same but to a lesser degree.
    Using premium (91+ octane) lessens the severity of the surging for me. Anecdotal? Sure. YMMV.
    Driver's Ed Fadclt's Avatar
    Jan 2018
    38
    I get an lspi event at around 50 mph low rpm and increasing throttle without downshifting. Now lately I get it all the time. Running 93 octane changed air filter. It was knocking before I changed air filter. No CEL. Dealership stated they cant do anything unless a light comes on or it blows up. Nice customer service GM.
    770
    Quote Originally Posted by Fadclt View Post
    Dealership just being lazy. If they can duplicate the concern they are likely to be able to diagnose it and repair it, getting g paid by GM to do so. They probably just have no clue what to look at since there's no code , sign of a lazy/crappy tech, especially if the concern is easily replicable. That would mean they could log the event with the scan tool and send it to GM for diagnostic assistance as well. It's laziness or ineptitude if the problem is easily duplicated. Poor customer service to boot. Trying another dealership possible?
    jblackburn likes this.
    Jan 2018
    38
    I took the tech for a ride and he heard it and said I dont know what it is. Service manager said GM wont pay to check the pistons for damage. I kinda stuck because there is so many dealers around here that if you didnt buy the car from them they wont look at it. I'm going to have to try and call GM directly. That's a whole bunch of fun!
  10. Remove Advertisements
  1. No cel or codes, but concerned
    By Cruzen18 in forum Gen2 Service Issues
    Last Post: 07-30-2018, 07:01 PM
  2. Bad Misfire, throwing p0301 and p1101 codes
    By fhsc5823 in forum Gen1 Powertrain
    Last Post: 05-28-2018, 02:27 PM
  3. Got 4 codes: 3 were P0324 and 1 was P0326; they all say knock sensor
    By alyssabesy in forum CruzeTalk New Member Introductions
    Last Post: 04-06-2017, 03:42 PM
  4. Misfire No Codes Or Lights
    By ehousel in forum Gen1 Service Issues
    Last Post: 10-18-2014, 08:31 PM
  5. Knock Knock...
    By XtremeRevolution in forum Off Topic Discussion
    Last Post: 03-17-2013, 10:21 AM
