Anyone know what this bolt hole is for? - Page 2
Results 11 to 13 of 13
Like Tree5Likes
Thread: Anyone know what this bolt hole is for?
    Scrubbydo1 is online now [OP]
    Apr 2019
    Hennepin County, MN
    86
    It’s easy as pie. Take off engine cover and weird heat absorbing foam thing (why the **** is that there?) You pull the clip back that holds on charge pipe, it can’t fly away. PulI clip and remove plastic connector from throttle body. Four bolts, one on each corner, all facing you, unbolt. Take out. If you are installing a boost gauge or water/methanol injection kit, put those taps in now. If you use a 90 degree brass elbow, make sure it will clear the outside of the spacer. Otherwise install plugs on spacer provided by BNR. Flat side down/plenum side up (not that you’ll be able to see it, but the BNR print on spacer is rightside up, you want the taps facing the rear of the car. Use new Allen head bolts provided by BNR. Put back together. Easy as pie. 15 minute install. Also, be smart and buy good permatex high performance thread sealing for all fitting connections to gauges/injections.
    Handbrake Released Iamantman's Avatar
    Sep 2018
    119
    Excellent. That looks like a breeze. Thanks for the pics!
    Apr 2019
    Hennepin County, MN
    86
    Addendum: you do not have to unbolt charge pipe from side of block, or remove entirely. I just pulled the hose that is sitting in a open plastic clip to the right of the engine block, on top of charge pipe, out of the clip. The lifted the charge pipe up and pulled back toward me to rest with the lip of the charge pipe sitting on a bolt on the valve cover. You will need a 7 or 8 mm wrench/socket ( can’t remember which ), and the bolts provided by BNR are Allen head.
  1. Sealing Valve Cover Bolt w/ Stripped Bolt
    By beermoney in forum Gen1 1.4L Turbo
    Last Post: 01-17-2019, 02:36 PM
  2. BOLT & BOLT Tax Credit Thoughts?
    By Eddy Cruze in forum Off Topic Discussion
    Last Post: 01-23-2017, 08:40 PM
  3. How to fix the hole in your eco trunk
    By Cruze_EcoJAY in forum Gen1 Interior Tutorials
    Last Post: 12-10-2015, 10:37 AM
  4. Hub Adapter/Hole Drilling question
    By RoadRage in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 06-21-2013, 10:31 AM
  5. Pics of front plate holder hole plugs
    By evo77 in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 11-07-2011, 01:22 AM
