EGR/DPF Delete - Page 5
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 50 of 50
Like Tree4Likes
Thread: EGR/DPF Delete
  1. #41
    Apr 2018
    Illinois
    372
    Quote Originally Posted by //oilburner View Post
    Attachment 271525For my education, what is the issue (system function, failures, resulting impact) with the EGR circuit in the GEN2 Diesel.
    From this diagram, my #1 question would be: Why don't diesel engine designers withdraw exhaust gas AFTER it has passed through the DPF and feed it into the air intake prior to the compressor? It seems that most diesel engines would benefit from being fed exhaust gas that has been filtered rather than the dirty, soot-laden exhaust that is put into the intake.
  3. #42
    Off-Road Champion boraz's Avatar
    Aug 2013
    BC
    2,436
    Quote Originally Posted by Barry Allen View Post
    the dpf would fill up faster, requiring more regens, shortening the life of the filter
    the exhaust gas into the egr is supposed to reduce nox, because of the cooler temps....now try to cool the exhaust gas post dpf during a regen...good luck.
    2014 Cruze Diesel - White 140,000 km
    1998 XJ 3" 31" Hakka LT 350,000 km
    1998 XJ 3" 31" Hakka LT 320,000 km
  4. #43
    Apr 2018
    Illinois
    372
    Quote Originally Posted by boraz View Post
    I'm no expert but I think EGR is turned off during regen. The EPA allows disabling of exhaust treatment systems during certain periods of operation of engines (such as if engine damage would occur, if engine operation is a certain condition is a very small part of the time the engine is operating, etc.). I think DPF regen is a cycle where EGR is turned off so temperatures can be boosted to burn off the soot load in the filter.
  6. #44
    2nd Gear sailurman's Avatar
    Sep 2016
    432
    I apologize about not being verbose enough - my rephrased question is - What is it about the Chevrolet GEN2 Diesel's EGR system that causes it to fail or cause other issues? Could an improvement (perhaps from another Diesel system made by another manufacturer) improve upon Chevrolet's design to prevent or prolong the EGR issue?
    And the answer sir is that there are no issues with the Gen2 Diesel worthy of performing any modifications (delete). Nor are there in the Gen1 now that the bugs are worked out of it. Fire away!!!!
    2015 Chevy Cruze CTD 120K (DEF Tank Replaced)
    2013 Chevy Sonic 1.4T Hatch
    2005 GMC Yukon XL SLT 2500 8.1L(496 Big Block)
  7. #45
    Aug 2013
    BC
    2,436
    makes sense
  8. #46
    Apr 2017
    108
    Heard this is what the new Silverado Diesel is doing, I would think the DPF would clog less since the filtered exhaust after it would be fed into the egr.
    The egr doesnt filter air in the current state so why would it clog the DPF sooner?
  9. #47
    418
    Quote Originally Posted by C4r7m4n View Post
    I emailed and received response that Oz Tuner has done the necessary deletes but are working on a security method...So basically they would rather develop something and keep it from the market than release it and have people copy there work.
    Um, I bet they're talking about the security in the cars PCM and not so much the security on their tune.
    These newer PCMs are nothing like the ones from just a few years ago.
    The biggest issue with EGR on diesels is the cooler clogging with soot, coolers leaking coolant internally into the engines intake manifold / cylinders and EGR differential pressure sensors clogging up.
    To get to the EGR cooler on some engines is NOT an easy task.
    I haven't really looked at our engines but I'd be willing to bet it's not too hard on ours to replace in the future when needed.
    2018 Cruze RS Hatch Diesel A9
    Factory retrofits: 120v inverter.
    Future retrofits: Auto HVAC, auto up driver window, turn signal mirrors, auto dimming interior mirror.
    1st Gen: How to make your ECO take 15.6 Gallons of fuel properly:
  10. #48
    Apr 2019
    10
    Quote Originally Posted by firehawk618 View Post
    Um, no you are flat wrong.
    This PCM is fully supported by EFILive. It's nothing like the 2.0 platform. It's just that EFILive no longer deciphers the code to allow DPF & EGR delete otherwise anybody with the software could delete like the good old days, just costs you $125 for a VIN license.
    So what I posted is accurate, they have unlocked the parameters but aren't willing to share because they can't properly secure it.
  11. #49
    Mar 2018
    21
    Were you given a timeline? Looks like trifecta won’t be tuning our Cruze CTD’s anymore.
    TRIFECTA: Get Tuned. (2017 Cruze / Cruze Hatch Support Now Available!)
    https://r.tapatalk.com/shareLink?sha...6&share_type=t
  12. #50
    Apr 2018
    Illinois
    372
    Quote Originally Posted by HondaTech2016 View Post
    EGR currently unfiltered goes through the engine and some (the majority?) of the soot that goes back through the engine is combusted instead of landing in the DPF. If we start taking EGR from after the DPF, 100% of soot from combustion lands in the DPF.
  1. Cruze Diesel DPF EGR SCR Delete Review and Thoughts
    By jakenkaiser in forum Gen1 Diesel Technical Discussion
    Last Post: 05-15-2019, 07:49 PM
  2. How to: DPF, DEF removal and downpipe/egr delete/oz tuning flash install.
    By HarleyGTP in forum Gen1 Diesel How-To & DIY Library
    Last Post: 03-28-2019, 11:45 AM
  3. Newly discovered DPF delete tuning source
    By electrozap_29 in forum Gen1 Diesel Technical Discussion
    Last Post: 03-25-2018, 04:54 PM
  4. DPF delete issues
    By 14cruzLUZ in forum Gen2 Diesel General Discussion
    Last Post: 01-14-2018, 10:50 AM
  5. EGR Delete questions
    By Skyviper in forum Gen1 Diesel General Discussion
    Last Post: 01-05-2018, 07:24 PM
