Side marker lights possible?
Results 1 to 7 of 7
Thread: Side marker lights possible?
    Knapman is offline [OP]
    Jul 2018
    Ontario, Canada
    89
    Hi there so I have recently been working on a new bumper and I have filled in my marker lights and I would like to make cuts in the fenders a install marker lights there. I would like to install a set of oval amber side marker lights I like the style from the jetta. I found a pair pretty cheap online https://store.ijdmtoy.com/LED-Side-M...n-p/75-084.htm I was wondering if it would be possible to wire these into the current marker light wiring? Then just relocate the wiring to reach where I will be putting them in the fenders. I don't know much about wiring so I figured someone here might know a bit more.
    5,771
    Quote Originally Posted by Knapman View Post
    I would try and find the current draw or the lamp style that those markers require and match it up to the Cruze markers.
    Are you taking pictures? I was considering changing a few things on mine, but I am not a plastic guy, so I could use some visuals, materials info etc. Maybe you could write a How-To: on the process.
    ChevyGuy's Avatar
    US
    7,379
    Do you have safety inspections in your state? They might fail you for removing the side lights in the front. The lights you're adding are European style, but they might be in addition to the regular front side lights.
    '13 LTZ
    Prior rides:
    '67 Chevy II, 250 ci/auto
    Jul 2018
    Ontario, Canada
    89
    I won't be tackling it for a little bit as I have a lot going on with the car right now but I will be doing it in the near future. Hopefully next month. When I do I will take some pictures step by step and try to write up a detail DIY for you and anyone else looking to do something similar.
    I tried searching online but haven't really came up with anything. How would I go about finding the current draw of the marker light? I'm assuming you mean how much volts/amps it takes to power the light? Could I manually test this if this is what you mean? With some type of voltmeter? Sorry I'm a total noob with wiring. Like could it be as easy as checking to see if it gets the same voltage then just chopping the wires and splicing the right ones together? Lol.
    VW SOCKET
    cp024643-side-marker-bumper-light-bulb-socket-plug-wiring-pig-tail-vw-jetta-passat-golf-3.jpg
    CRUZE SOCKET
    Quote Originally Posted by ChevyGuy View Post
    Now I haven't actually looked into the laws around here. I am just assuming that it's okay. I see cars around here often with no marker lights in the front bumper and only have them in the front fenders and we don't really have inspections from my experience unless the car is heat score and the MTO wants to be jerks. Usually just lowered cars with loud exhausts. I live in Ontario, Canada.
    5,771
    The voltage is 12v. As for the amperage, if you know someone with a DC amp clamp you can measure yourself without cutting the wires. The only other way to directly measure is to insert an ammeter into that circuit, which means cutting a wire. i was suggesting doing a Google search though.
    Jul 2018
    Ontario, Canada
    89
    I tried searching online but haven't really came up with anything. How would I go about finding the current draw of the marker light? I'm assuming you mean how much volts/amps it takes to power the light? Could I manually test this if this is what you mean? With some type of voltmeter? Sorry I'm a total noob with wiring. Like could it be as easy as checking to see if it gets the same voltage then just chopping the wires and splicing the right ones together? Lol. <img src="https://www.cruzetalk.com/forum/images/smilies/unsure.gif" border="0" alt="" title="Unsure" class="inlineimg" />
    Okay yeah all these lights run off the 12v system. I read that the left parking light, tail lights, front and back side lights of the Cruze are all on one circuit - a total of 5 lights. They all run off of Fuse F3 in the instrument panel. I also learned the Parking lights left, side marker left, instrument cluster backlights of the Jetta run on one circuit and the fuse is S22 and it says 5 amps.
    http://web.mit.edu/dennis/www/vw/fuses.html
    The F3 fuse is 15ah250v and I couldn't find much on the S22 but I think it's 2ah250v. Could I know just by the difference in the fuse? Or because the circuit runs different things it would be sending different amperage to different lights? So I would have to check the amp going to the marker light itself? Sorry I'm a total noob with this kinda stuff. &#x1f604; just trying to see if I can figure it out before I go out and get something to actually test it manually am i kn the track here or just chasing the wind?
    829
    Side marker lights are 194s correct? They draw approximately .25amps each.
  10. Remove Advertisements
  1. Replies: 0
    Last Post: 08-05-2017, 02:23 PM
  2. Cruze Side Marker
    By CHEVYCRUZE RS in forum General Discussion
    Last Post: 04-24-2015, 09:16 AM
  3. Front Bumper Side Marker Lights
    By dw1997 in forum General Discussion
    Last Post: 03-10-2014, 04:33 PM
  4. Part number for passanger side side marker.
    By Nobody in forum General Discussion
    Last Post: 04-06-2013, 11:03 AM
  5. Light smoke side marker lights
    By cruzeman in forum Buy/Sell Classifieds
    Last Post: 05-30-2012, 04:56 AM
