No taillights No marker light on drivers side - Page 2
Results 11 to 13 of 13
Thread: No taillights No marker light on drivers side
    ChevyGuy's Avatar
    US
    7,335
    Quote Originally Posted by mike_barbato View Post
    The harness was there but the connector had been either cut off or pulled off..very strange.
    As far as the connector, it may not have gotten all the way "clicked" on at the factory and just worked itself loose.
    '13 LTZ
    Prior rides:
    '67 Chevy II, 250 ci/auto
    Banned
    10,296
    Cruze uses those tab bulbs like this.
    They are not any better than the old fashion bayonet type bulbs, that need a brass base and a brass socket to turn them into, but definitely cheaper to manufacture. Instead of brass, and should be plated, use a piece of plastic with what should be a double U-shape tab hot on both sides, Cruze is only using a single tab.
    On one of my back up lamps, that single tab was put in on the wrong side from the factory, so that bulb wouldn't work at all, I had to bend those cheap wires to the other side. Told my dealer about this, that harness is rather short for all the lamps, but refused to replace it, as long as bending those tabs to the other side worked.
    Also the brass tabs inside that plastic housing can corrode so you don't make good contact, can be cleaned and coated with silicone to help retard corrosion.
    Do you think there is a conspiracy between the cops and these socket manufacturers, so cop has a right to stop you in one bulb out? In Wisconsin, also have the right to search your vehicle when stopped. Not sure about other states.
    Oh, and if Black and not cooperative, they will shoot you, because of a cheaply made bulb and socket.
    Banned
    10,296
    Also found it convenient for me to open up that grommet that prong of the tail lamp housing plugs into and coating that with silicone grease.
    Darn thing was so tight from the factory, darn near broke the housing trying to pull it out, not a darn reason in the world it has to be that tight. Think a member of this board said he broke his housing. I used a suction cup and a tow truck to pull mine out the first time.
    For years been carrying a full complement of replacement bulbs and the tools I need to change them along with fuses all in a plastic bag sitting on top of my spare tire. With an easy to remove tail lamp housing, just a small phillips screwdriver.
    For practically all vehicle I have owned for the front amber directional and parking, used a colored lens for this, same clear bulb as the rears. Cruze just had to use an amber bulb for this so had to buy two more. Its little details like this that tend to make me hate bean counters even more.
    This way if stopped, a bulb can burn out at anytime, can change it then and there to avoid getting a warning ticket, then having to mail that in once a bulb is replaced.
    Those front bumper marker lights are a pain to replace, have to turn the front wheel in, and pop out a bunch of those push pin rivets at the wheel well. Not even sure they are there, just a tiny 2 watt 194 bulb in there, with plenty of side lighting with that head lamp housing clear around the side. Can't even notice if they are on or not.
    And it sure doesn't help getting all of this made in China crap.
  1. Cruze Side Marker
    By CHEVYCRUZE RS in forum General Discussion
    Last Post: 04-24-2015, 09:16 AM
  2. OEM Fog Lights- Just need Drivers Side Bezel, Light
    By trip in forum Buy/Sell Classifieds
    Last Post: 09-03-2013, 11:33 PM
  3. Part number for passanger side side marker.
    By Nobody in forum General Discussion
    Last Post: 04-06-2013, 11:03 AM
  4. Light smoke side marker lights
    By cruzeman in forum Buy/Sell Classifieds
    Last Post: 05-30-2012, 04:56 AM
  5. Tail light and side marker overlays
    By Xlr8machineshop in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 04-16-2012, 06:52 PM
