15 ctd won't start or run - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 41
Like Tree18Likes
Thread: 15 ctd won't start or run
    Rivergoer's Avatar
    Mar 2017
    Parker, AZ
    2,354
    @IndyDiesel , Super glad it's fixed so quickly and easily, thanks for keeping us updated.
    I miss @diesel and his contributions. Text him hi for me.
    2014 White Cruze Diesel, 3rd Owner, Bought 3/17 With ‘09 TDI Buyback $$$
    2006 Dodge Ram 3500 Laramie Megacab 4x4 Cummins Dually, 245,000 Miles
    1987 Chevy 3/4 Ton 4x4 Suburban, 383 Stroker, North of 300,000 Miles
    Thank you Veterans!
    IndyDiesel is offline [OP]
    May 2015
    2,219
    The EGR for those that do not know is on driver side back of engine down a few inches. It's black and has a red electrical connection.
    Tools needed are a T30 or torx 30, really need 3-4 inch extension. I picked one up at Sears in some silly kit for 20 bucks.
    1.) remove the electrical connection, just tab on top.
    2) use the T30 to remove the two long fine thread screws, one on top which you can see, and one on bottom which
    Can't see.
    3) there is a bracket and a line and hoses that are in the way, rotate the EGR counter clockwise maybe a quarter turn so you can remove the EGR.
    4) I cleaned mine, gm new ones are on eBay for 125, either clean really well or replace with new one.
    5) reinstall and connect electrical connection. I tested mine not in to make sure it would close prior to putting back in car, kinda smells with smoke to do that. I also lubricants the valve shaft with some brake exhaust lubricant, it was thick. I made sure to clean well and make sure the valve moved freely.
    It is a pretty easy job, I will in future remove and clean maybe every 35-40k miles and may even have a spare valve in the car in case I have an issue like @Gator had on vacation. I think if you clean it on regular basis would never have a problem.
    I buy my fuel at just three stations most of the time. I drive mostly highway.
    Hope this helps.
    obermd, Tomko and Rivergoer like this.
    2018 Chevrolet Cruze Sedan Premier RS 11k
    2003 Buick Park Avenue 80k
    2004 Ford F-150 Reg Cab, 4.2L 45k
    2005 Mercedes E320 CDI 190k
    2015 Chevrolet Cruze CTD 71k traded
    2004 Cadillac Deville DHS 90k SOLD
    2002 Ford F-150 extended cab 4.6L 133k. SOLD
    3rd Gear Gator's Avatar
    Jul 2013
    Hamilton,Ohio
    682
    Thats great you got it fixed. Ive been trouble free since it was replaced. 165000 on the car now
    Mar 2016
    Canada
    283
    Wow thanks for the info and pic.
    Cheers.
    IndyDiesel likes this.
    Off-Road Champion boraz's Avatar
    Aug 2013
    BC
    2,436
    title should be edited to reflect the repair
    no one in the future will find it otherwise
    Cruzator likes this.
    2014 Cruze Diesel - White 140,000 km
    1998 XJ 3" 31" Hakka LT 350,000 km
    1998 XJ 3" 31" Hakka LT 320,000 km
    May 2015
    2,219
    Quote Originally Posted by boraz View Post
    That's fine on my side. I also plan to show a pic of what EGR looks like installed and it's location on the engine. Prior to this problem, I didn't know where it was located.
    I left my little tool pack in the trunk, just in case I ever need to remove on the road.
    The forum and all saved me several hundred $$$ since no tow bill and the dealer just replacing the valve vs cleaning it.
    Aug 2013
    BC
    2,436
    Quote Originally Posted by IndyDiesel View Post
    assuming you reused the gasket?
    May 2015
    2,219
    I did, would be better to replace
    Aug 2013
    BC
    2,436
    is it traditional gasket material or ?
    i considered inspecting my egr couple mos ago, but didnt wanna screw the gasket up
    May 2015
    2,219
    I didn't even look...should have...I did test the EGR to make sure it would close just by hooking up the EGR not installed, yikes it's a smoky mess, shut car off quickly. Amazing it lasted as long as it did. The emission system has issues for sure, but dang it cleans up the soot and mess pretty well
  1. Replies: 32
    Last Post: 06-21-2018, 10:39 PM
  2. Replies: 3
    Last Post: 05-29-2018, 03:37 AM
  3. remote start run interval?
    By ls3c6 in forum General Discussion
    Last Post: 12-30-2017, 09:49 PM
  4. Car won't start, dealership run around.
    By swelch in forum Gen1 Service Issues
    Last Post: 04-07-2016, 04:37 PM
  5. CTD won't start
    By Black20cruze in forum Gen1 Diesel Technical Discussion
    Last Post: 08-23-2015, 12:35 AM
