2014 Diesel CV Joint Failure? - Page 5
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 46 of 46
Like Tree35Likes
Thread: 2014 Diesel CV Joint Failure?
  1. #41
    Rivergoer is online now [OP]
    Rivergoer's Avatar
    Mar 2017
    Parker, AZ
    2,333
    Quote Originally Posted by MP81 View Post
    I'm afraid it would have been a fight had I not removed the oil drain/gutter/garbage part.
    ......the drain/gutter/garbage part THAT WAS DEFECTIVE, SHEARED OFF AND LAYING IN THE BELLY PAN......
    Based on my experience I can say with certainty that removing the ‘culprit’ BEFORE visiting the dealership led to the proper outcome in your case.
    Glad it worked out!
    2014 White Cruze Diesel, 3rd Owner, Bought 3/17 With ‘09 TDI Buyback $$$
    2006 Dodge Ram 3500 Laramie Megacab 4x4 Cummins Dually, 245,000 Miles
    1987 Chevy 3/4 Ton 4x4 Suburban, 383 Stroker, North of 300,000 Miles
    Thank you Veterans!
  3. #42
    MP81's Avatar
    Washington Township, MI
    3,593
    As am I! The car was at the dealer for longer than I expected, but we had a brand new vehicle for a loaner during that time (one of those mornings being -12 where other diesels in the area - including an Equinox Diesel - did not start) so no issue there. No dealer in the area had one of those axles, so they had to special order.
    Again, had I not known about the likely culprit, I'd likely have to pay to replace the axle - or had to expend a bunch of energy to make them do it for free. That would have been awful. Still mindblowing it's not covered.
    Rivergoer likes this.
  4. #43
    Handbrake Released HarleyGTP's Avatar
    Dec 2013
    Campbell Hall, NY
    166
    Went to do an oil change today, guess what I found laying on the belly pan!!!! Deflector sheared right where everyone else's did. Part is cheap, the oil change was more of a mess than usual and took the PS wheel off to fish out the deflector.
    2014 Chevy Cruze Diesel, full delete.
    1995 Dodge Ram 2500 Diesel "Nancy"
    2004 Harley-Davidson Road King Custom
  6. #44
    Rivergoer's Avatar
    Mar 2017
    Parker, AZ
    2,333
    Quote Originally Posted by HarleyGTP View Post
    Be sure to inspect the CV boot for cuts/damage, could lead to premature CV axle failure.
    MP81 likes this.
    Thank you Veterans!
  7. #45
    Dec 2013
    Campbell Hall, NY
    166
    Thanks! Will do.
    MP81 and Rivergoer like this.
  8. #46
    MP81's Avatar
    3,593
    It must've fallen further into the center of the car than mine did. I was able to lay on the ground and reach up and over the axle and down into the belly pan, pick it up, and drop it out onto the ground.
    As @Rivergoer mentioned, definitely check that inner boot there. It falls directly onto it - wonderful design.
  9. Remove Advertisements
  1. Outer CV Joint
    By Joe.F in forum Gen1 Service Issues
    Last Post: 09-16-2016, 03:02 PM
  2. whats a safe distance between the strut and cv boot?
    By Blue_RS in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 12-19-2015, 12:53 PM
  3. Lower control arm/ball joint
    By TheKidJoey in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 08-09-2015, 03:09 PM
  4. Recall notice in the mail today. CV shaft problem
    By firehawk618 in forum Gen1 Service Issues
    Last Post: 11-27-2013, 12:05 PM
  5. Roof Panel Joint Finish Moulding - How do you remove them?
    By phantom in forum General Discussion
    Last Post: 10-03-2012, 10:31 PM
