White smoke puff from grill at stop light.
Results 1 to 10 of 12
Like Tree3Likes
Thread: White smoke puff from grill at stop light.
    newsguy99 is offline [OP]
    May 2013
    411
    Well, today, it happened... Drove to a delivery drop off from an Interstate at around 70ish mph... Come to the top of the exit ramp, stop light... Stop... White puff of smoke comes from the grill area...
    I thought, it might of been the truck in front of me.. So, didn't think much of it... Drove a bit more down the road (40ish mph), stopped at another stop light.. More white smoke.. Now, I'm starting to worry.
    Get to my delivery.. get out of the car and open the hood, car is still running.. No smoke, no leaks I can see, and there's still plenty of coolant in the reserve.. Leave the hood up while I finished the delivery up, and turned the car off.
    Got back in... Car started, and ran fine... However, at my next stop, again, more white smoke. Now, its not a lot.. its just a small puff.. But worrying.
    By this time, I'm now on the DIC screen with my temp... Its reading from 210, to 220 max... and then goes up and down between those.. While stopped at a light, or coasting, it goes into the 190s...
    Is this a sign the turbo has some oil in it, and nothing more? Or is the thermostat stuck, or could it be a water pump issue?
    Taking it into the dealership tomorrow morning, so they can look at it. And, when I went to capture it on my cell phone camera, luck would have it... It wouldn't do it. Suggestions? Comments?
    This is my first turbo car... so, I'm clueless about it...
    I've also noticed a much louder than normal ticking as the engine is running... could this be spark plug gap related?
    World Rally Champion
    Aussie's Avatar
    Sep 2012
    Sydney, Australia, Suburb called Lalor Park.
    4,069
    Does the smoke just keep rising up or does it evaporate quite quickly?
    2012 Holden Cruze CDX Diesel, Nitrate Silver,
    Tinted windows, SRI-V wheels. Built July 2012, MY13 model
    May 2013
    411
    real quick.. just a puff.. its white... and then nothing at all...
    5th Gear 99_XC600's Avatar
    Massachusetts
    916
    I don't see how it could be the turbo for the fact if it was consuming oil or coolant, the smoke or steam would either be ingested into the intake or blown out into the exhaust. Unless you have a leak in the Intake tubing or in the intercooler somewhere and you have a bad turbo to boot, but it seems unlikely.
    The operating temps seem to be fine.
    2013 Cruze ECO Silver Ice Slushbox with MyLink. AKA "Silver Slushie"
    2006 Polaris FST (Four Stroke Turbo) with ECU Reflash. 165 HP from a 750CC Engine. Turbos = Fun
    Mod's
    Resonator Delete
    Gapped Plugs
    Tint - 35%
    Fog Lights - SpyderAuto.com
    Dipped Badges, Letters, Lower Intake and Rear Diffuser Panel
    $16 Chinese Mud Flaps
    Drag Racing Champion Dragonsys's Avatar
    May 2013
    DFW, TX
    1,673
    could it be condensation from the A/C dripping on something hot?
    2011 Taupe Grey Metallic ECO M6 (Hidden Content - Hidden Content )
    May 2013
    411
    Quote Originally Posted by Dragonsys View Post
    don't think it is.. I've never noticed it doing this before... After it happened the 2nd time.. I turned the a/c off, just to make sure..
    May 2013
    DFW, TX
    1,673
    hmmm well from what you have described it almost has to be water, the olny other thing i can think of would be coolant leaking from the rad area. I would get a dye kit and check it out. It could be a small enough leak that you don't notice the level drop
    Massachusetts
    916
    Start checking for signs of wetness around all of the cooling hoses and lines going to the expansion tank. Also another thought I had, is that the modern radiator is constructed of an aluminum core with plastic tanks on the sides. It's possible that one of the tanks has a crack in it and your seeing some steam escaping from it. This is just a guess though. Jeep/Chrysler had this issue with the Liberty's where the tanks would actually split and cause a major coolant loss.
    I would take a piece of cardboard and put in under the car and let it sit overnight and check for any leaks.
    Mod's
    Resonator Delete
    Gapped Plugs
    Tint - 35%
    Chevy Customer Care's Avatar
    Oct 2011
    Detroit, Michigan
    5,722
    Originally Posted by newsguy99Well, today, it happened... Drove to a delivery drop off from an Interstate at around 70ish mph... Come to the top of the exit ramp, stop light... Stop... White puff of smoke comes from the grill area...
    Hey Newsguy99,
    I'm sorry to read that you are having this issue. Please follow up with us after your trip to the dealership and let us know what the results are.
    Marlea Wilson
    Chevrolet Customer Service
    5,158
    Have the dealer add ultraviolet (UV) dye to the coolant. Then track the level over the next few weeks.
    Another possibility is that you were seeing water condensing on the low-pressure side of the A/C, and somehow getting kicked onto something hot.
  1. White Smoke on Heavy Throttle
    By Dieselard in forum Gen1 Powertrain
    Last Post: 04-30-2013, 09:36 AM
  2. Rough start and white smoke??
    By MafiaLTZ11 in forum Gen1 1.4L Turbo
    Last Post: 07-01-2012, 06:38 PM
  3. Light smoke side marker lights
    By cruzeman in forum Buy/Sell Classifieds
    Last Post: 05-30-2012, 04:56 AM
  4. White Eco with White grill
    By Keyzbum in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 05-07-2012, 01:55 AM
  5. Smoke from grill of my car
    By Dlnn12 in forum Gen1 Powertrain
    Last Post: 03-05-2012, 10:08 AM
