Load Resistor/Ballast Mounting Recommendations? - Page 2
Results 11 to 20 of 24
Like Tree16Likes
Thread: Load Resistor/Ballast Mounting Recommendations?
    Mar 2019
    17
    Quote Originally Posted by Ncfutrell View Post
    On my 17 hatchback, there are separate lights for the brake and turn signal.
    I wonder if there is a way to get that on my sedan. I bought an LED tail light assembly but it requires a separate plug for the turn signal and the brake light
    NoDiggity247 likes this.
    Learning about my Cruze Ncfutrell's Avatar
    Feb 2018
    Gaston, NC
    66
    Quote Originally Posted by chrisbrad91 View Post
    You could cut the turn signal wire, and splice a wire into the ground. Connect the newly spliced ground and newly cut turn signal wire to the correct bulb socket, and you are golden.
    Update!!!!!
    Solved the mounting issues with the front. Take a pic when I have it mounted.
    I cut a 4x3.5 square/rectangle (lol) marked the holes for the two resistors, drilled them, grinded the mounting plate into shape. and mounted the resistors: only after extending my wires. I drilled a 5/16” hole in the upper corner for mounting. Will post pics when installed.
    Also, I have enough pics to do a how-to for this and for installing eibachs. Will do once I find the time.
    Feb 2018
    Gaston, NC
    66
    Mounted.
    Feb 2018
    Gaston, NC
    66
    Routed, loomed, spliced. Done deal. Remote mounting the resistors seems to be working well, so far.
    I ran the wires beneath the crossmember and into it; the entire length until I reached the air intake snorkel.
    The crossmember/support to the right. That is where I ran my wires for the right turn. I ran the two wires where the yellow lines, or green, are. (Or whatever color, I’m color blind.) Hidden.
    I came out of the crossmember just beneath the snorkel, and back around to the turn signal. The wire loom you see is where I ran my wires.
    All loomed and spliced.
    I’m going to tape the extra before the loom and you’ll never see my wiring again lol.
    Between the two of you, you could write up a nice How-To to add to our collection
    How-To: Write a Tutorial
    Anyway, hope that helps. I’ll write a how-to if someone doesn’t beat me to it. I’ll try to find the time tonight; if not, then I’ll do my best to produce one by tomorrow night.
    Mar 2019
    17
    Thats awesome how you wired the resistors for the front led turn signals
    Mar 2019
    17
    I will have to take another look at the wiring in the back of my sedan and see if the wiring is set up to use one wire as coming from the turn signal and another wire as coming from the brake light. Right now there is one harness to the rear lights that have 3 wires (1 of which is ground). If thats the case, then I should be able to (like you said) cut the wire and make a second plug for the turn signal and connect the ground wires together.
    Ncfutrell likes this.
    3rd Gear
    669
    You need to either modify the vehicles wiring, or use converters like a Curt C56196
    Mar 2019
    17
    Quote Originally Posted by Ma v e n View Post
    Thank you. I was wondering if there was a convertor out there that I could use.
    Jun 2018
    7
    Helps?? This more than helps. This is AMAZING!!THANK YOU for showing the way!!
    Sorry I am just getting caught up with everything. This post got some good attention!! NICE!
    *I since I have been practicing soldering the last couple days, I think I might as well extend my wires as well. Such a smart move
    *I was about to check the harness inside the body, test the wires and find out which one ran the signal. . . Again, I like your method much better
    FRONT
    *The looms seriously help out with keeping everything clean.
    *I need to find a scrap piece of metal... I may try this if I can find something
    REAR
    *Funny thing about the rear setup. I ran across a a Uhaul video that was doing wiring for a trailer and they used the grommets to feed the wires. Duh, a much better approach. I was about to cut the grommet but I like how you did the holes instead.
    Jun 2018
    7
    Also quick question. Do the taillights your Cruze Hatchback have a bulb for the brake light and one for the turn signal. I have the sedan and there is only one bulb for both light function. I'm trying to find a way to separate the light function so that they work with the aftermarket taillights that i got.
    Yeah, there is a separate bulb for everything. I will say that I am VERY happy they went with the amber turn signal instead of the integrated tail/turn red light.
  1. HID Mounting ballast
    By bstnian25 in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 12-03-2015, 07:32 PM
  2. Lowering Springs - Daily Driveability, Load, Height recommendations
    By inssane in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 01-20-2015, 11:55 PM
  3. Toyota Engineering? 88 Supra Blower resistor.
    By NickD in forum Cruze Owners - Other Cars/Toys
    Last Post: 05-12-2012, 08:25 AM
  4. HID Ballast Placement
    By Morbidity in forum Gen1 Audio & Electronics
    Last Post: 03-09-2012, 10:33 AM
  5. 1.8 Ballast Location
    By Mick in forum Gen1 Audio & Electronics
    Last Post: 02-28-2012, 12:05 AM
