Load Resistor/Ballast Mounting Recommendations?
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Like Tree16Likes
Thread: Load Resistor/Ballast Mounting Recommendations?
    Jun 2018
    7
    2017 Cruze Hatchback RS here.
    Wondering where anyone has mounted Load Resistors or Ballasts for LED upgrades? Especially the rear lights. I trying to plan the best way to do an LED Turn signal upgrade.
    THANKS!
    UPDATE with details of my project
    OVERALL
    *Why am I doing this? I didn't want to but I my hand has been forced. I purchased "no-hyper flash" bulbs last summer. . . . the barely lasted a couple months. After about 30 seconds, I would get hyper flashing. I'll post a link to what I got later.
    *I know the resistors come with quick taps but I plan on soldering the joints. This is strictly personal preference. I haven't run into any post of people having problems with the quick taps.
    *Good news, there are only two wires so I don't have to deal with figuring out which wire to tap. I'm not concerned that it can't be done now, it's just a matter of how I want to do it.
    FRONT
    *I am struggling most with where to best place the resistor in the front. The rear is less of an issue and I will get to that below.
    *One thought is to mount it under the angled beam that is just beside it. Sure, I could mount it on top or side but I don't want it to mess with the heat liner under the hood. Please tell me if I am overthinking this. The other reason I wanted it under, was for a cleaner look.
    REAR
    *I was hoping to tap the resistor further back and inside the body but the wires go into a harness before entering the body of the vehicle. I know nothing about electrical so I wouldn't know what to do behind the harness (on the inside of the body). If anyone does, please share! haha
    *My current approach is to drill a hole through the body and install a rubber grommet to seal out moisture. With the resistor mounted inside, I would feed it's wires through the hole and tap in from there. I just want to have room to pull the light assembly in and out without yanking everything apart accidentally.
    Learning about my Cruze Ncfutrell's Avatar
    Feb 2018
    Gaston, NC
    66
    Quote Originally Posted by NoDiggity247 View Post
    THANKS!
    I’ll be doing this tonight around 5-6pm eastern time when I am off work, so I’ll be sure to take some pics of where I am going to mount mine. I have yet to look, but I’m doing mine today as my load resistors came in earlier.
    yt400pmd and NoDiggity247 like this.
    Jun 2018
    7
    Good deal!
    I am going to be doing this on Weds (only because the weather will be warmer). This weekend I decided to take a look inside to come up with my plan. I updated my original post to share my thinking. I will take pics when I do!
    If I get a chance today, I may take some pics to diagram my plan.
    Feb 2018
    Gaston, NC
    66
    Good deal!
    Yea, from the way you describe it; we both have the same idea about the rear, and I’m sure there is somewhere close up front that I can mount them. I’m already expecting to lengthen the leads and mounting the resistors remote enough to be able to, like you say, pull the lights out completely without pulling wires. Will update as soon as I am off and get it done, boss.
    NoDiggity247 likes this.
    Feb 2018
    Gaston, NC
    66
    I got rained out last night, so I’m going to jump right into this today. I’m off work since it rained so much: even better lol.
    I ordered Aaron’s off of Amazon. 50w 6ohms. I got these because the leads are crimped and soldered beneath that heat shrink, instead of just soldered(poorly most of the time). I’ve used them on my 13 Silverado for about 3 years now with zero issues.
    Feb 2018
    Gaston, NC
    66
    I mounted mine within the kick panel area in the hatch for the rear turn signals. Poked a small hole through the rubber grommet the taillight wiring harness was through, and connected the wires as needed.
    First, I extended my wires.
    Marked the holes on the mounting tabs, drilled them, and mounted the resistors.
    I ran my extended wires through the rubber grommet.
    I cut the extra wire, and spliced then into the turn signal wires.
    And then I reinstalled everything.
    5,303
    Between the two of you, you could write up a nice How-To to add to our collection
    How-To: Write a Tutorial
    Mar 2019
    17
    THANKS!
    Hi there,
    I had just upgraded both my turn signals and headlight to LED. The headlights were not a problem. I just removed the dust cover, disconnected the halogen bulb and connected the LED. That light came with a decoder to eliminate the error messages. The bulb size for the Cruze is HB3/9005
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    The turn signals I have:
    I did have to order load resistors to get rid of the hyperflashing and it works great. On the front, I secured the resistors under the angled crossbar with zip ties for not. At some point, I will go back and permanently secure the resisters
    Mar 2019
    17
    THANKS!
    Also quick question. Do the taillights your Cruze Hatchback have a bulb for the brake light and one for the turn signal. I have the sedan and there is only one bulb for both light function. I'm trying to find a way to separate the light function so that they work with the aftermarket taillights that i got.
    Feb 2018
    Gaston, NC
    66
    Quote Originally Posted by chrisbrad91 View Post
    On my 17 hatchback, there are separate lights for the brake and turn signal.
  1. HID Mounting ballast
    By bstnian25 in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 12-03-2015, 07:32 PM
  2. Lowering Springs - Daily Driveability, Load, Height recommendations
    By inssane in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 01-20-2015, 11:55 PM
  3. Toyota Engineering? 88 Supra Blower resistor.
    By NickD in forum Cruze Owners - Other Cars/Toys
    Last Post: 05-12-2012, 08:25 AM
  4. HID Ballast Placement
    By Morbidity in forum Gen1 Audio & Electronics
    Last Post: 03-09-2012, 10:33 AM
  5. 1.8 Ballast Location
    By Mick in forum Gen1 Audio & Electronics
    Last Post: 02-28-2012, 12:05 AM
