2016 Cruze LED running lights only flickering- Any fix
Results 1 to 10 of 13
Thread: 2016 Cruze LED running lights only flickering- Any fix
    easygoin4 is offline [OP]
    Apr 2019
    23
    Just the running lights sometimes flicker, any way to fix this
    Has OEM headlights
    Thanks
    774
    Could be a poor connection, but flickering LEDs is usually the led itself. Which would mean new headlights needed to fix issue unfortunately.
    Apr 2019
    23
    I did take off caps and check all connections.
    Turned on and started and they were fine for a few then started again.
    Car is going to my daughter tomorrow I guess I can keep researching it.
    I would gladly change headlights bulbs if I knew it would fix.
    Thanks a lot for the help.
    4th Gear LiveTrash's Avatar
    May 2015
    Ontario, Canada
    702
    Quote Originally Posted by easygoin4 View Post
    If yours has the curved, white LED strip at the bottom of the headlight that act as the running light, then there is no bulb to replace. They're diodes inside the headlight that are almost not worth replacing. If they start flickering after a certain amount of time then there might be a heatsink issue. They may be overheating and flickering.
    BRUZER
    2014 Chevy Cruze Diesel | Crystal Red Tint Coat /w Cocoa Leather Interior | Safety and Convenience Package
    Modifications
    20% Window Tint All Around
    OEM Fog Light Install
    Hidden Content /w Hidden Content
    Equipment
    Apr 2019
    23
    Yes has the string of LED around the edge.
    So what is the fix- replace the entire assembly?
    Ouch-I think that will be costly.
    Thanks again
    Learning about my Cruze Ncfutrell's Avatar
    Feb 2018
    Gaston, NC
    81
    Mine were flickering due to a bad battery connection. I would check the condition of your battery, and its connections first.
    Apr 2019
    23
    Thanks will do....
    Apr 2019
    23
    Sorry to bring this back up..
    My daughter took to local dealer today in GR Michigan, and they blew her off. did not want to help her, told her probably easy fix- just don't want to find it. I thought they would diagnose it and apply charge to the repair (at least that is what I was told by another dealer).
    She loves the car just getting annoyed by the flickering DRL.
    Does anyone have a picture of the LED strip connection- maybe i can just disconnect it, she is fine with that, because the headlights work fine.
    Or I was thinking maybe i could just rewire direct to something else.
    I did find a bunch of wires and little black box under dash at left side almost fell out- thinking someone from the accident repair may have been into this area, and that is what causing the flicker.
    It was small gauge wires like alarm stuff. did this car come with factory alarm? The horn honks one fast beep, every time she turns the key
    off.
    Thanks again for any input - I wanna fix this for her.
    774
    Sounds like there's definitely aftermarket parts installed. The horn shouldn't do that when you turn off the car. There also shouldnt be any losoe jumbles of wires or small black box flopping about. The Body Control module is a black box above the park brake pedal, but it's the size of a book.
    There's no fuse you can pull to just disable the DRL strips. You'd need to disconnect the power wire to them out of the headlamp wiring connector. It's a 6way connector, the wire you want is in position 3, which is the wire with blue on the top row(close to the lock side)
    But I would definitely attempt to determine what aftermarket goodies are installed. Theres a real potential for the chase there.
    Apr 2019
    23
    Was thinking that jumble of wires could be aftermarket alarm, and maybe i could take to alarm place and have them disconnect the alarm.
    Thanks alot for the wire color and location..
    Will try it next time shes home bout a couple weeks.
  1. Replies: 11
    Last Post: 08-29-2018, 11:20 PM
  2. Flickering LED footwell lights and non-working remote
    By kilnakorr in forum Gen1 Audio & Electronics
    Last Post: 11-14-2016, 01:11 PM
  3. Replies: 20
    Last Post: 11-13-2016, 04:51 PM
  4. LED License Plate Lights Flickering
    By LiveTrash in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 02-11-2016, 01:20 AM
  5. Cruze 2011 saloon dash lights flickering and losing power
    By rjf10 in forum Gen1 Service Issues
    Last Post: 09-29-2015, 02:24 PM
