You should get on the CT facebook group if you aren't already. One of our customers is pushing 30+psi from our GTX and the thing is a rocket
I've been trying to contact you for a injectors and a tune through Facebook, badnewsracing.3dcartstores.com, and the forum here. Im ready when you are!
Just for context from the outside viewer, my situation is not plug and play. I have a 3in intake which is pleaging my MAF readings. Trifecta failed to tune dyno tune it and ignored me afterwards after dropping $1000 on them, then i tried to self tune and quickly ran into the same limits at Trifecta. Currently im using an old trifecta ECP tune on stock injectors to keep cruise control working with my 3in intake.
My bypass circuit also ruins the MAF flow reading, as its not an internal bypass but is being redirected into the intake.
And to be clear i want it all, cruise control, no rapid fueling changes from false maf readings when turbo is releasing pressure. And i want 30+ psi of boost, So im stuck between a specially made Tune or a specially made intake that can make a MAF sensor happy *if possible with external bypass
