All,
I found a coolant leak at the coolant outlet, and after searching I found it was a fairly common issue.
But I have a couple of questions:
It was mentioned that there is an upgraded part that requires a new hose. Does anyone know the new part numbers? The one part number I saw was 25193922 for the outlet. Is that new new part or the old one?
Thank you all in advance.
This is a 2012 that was originally purchased in late 2011, so I assume this is no longer covered under warranty and this will be a DIY endeavor.
