I'm not sure if that movement is normal or not. However the 1.8L is an interference engine. So if any of the timing components break and the engine skips time, it can cause ALOT of internal engine damage. If it were my car at 7-8 years old and 83,000 miles, I would be changing the timing belt as well as the other timing components to be safe. The recommended maintenance interval is 100,000 miles, so your almost there anyway.I made a previous thread but I want to make another one now that I have more information about this issue.
My 2013 1.8 Has been exhibiting a jerking sensation while in Drive. I now have caught the engine making a rhythmic grinding noise when it does this.
Here is a video of the noise.
I went out today to listen with a stethoscope to see if I could pinpoint the noise.
It was most prevalent when I placed it over the coil pack cover, but when I removed the cover I couldn't hear the noise. However, the jerking remained.
I thought it might have been the serpentine belt or the pulley on that but I heard nothing in that area.
I then removed the timing belt cover. I couldn't get the stethoscope in there to listen but what I saw was the idler/tensioner (not sure what it was) shaking a bit.
Here are videos of what I saw
My question is if this movement is normal or not? I have been digging into this for a while and I am out of ideas. Will probably take it to a shop soon but looking for advice first.
None of the timing components have been changed yet. Car has 84K miles
I don't think its a misfire issue as I recently changed the plugs and have and OBD2 scanner that isn't picking up misfires. Also no codes.
