1 - 14 of 14 Posts
okay this is for some 1.8L love for me your a stage 0 IF you have atleast a airbox reso delete with any aftermarket filter (1" foam removal included) or FULL INTAKE, A Muffler Swap or DELETE, GAP the SParks to .35, and a tune ...what more to make it up the levels i assume this is a real start and would wake your car up as confirmed by other memebers here ... this is for the 1.8 out there that want more ..share what you have
1.8L power mods this car needs
the trifecta tune offered from GM
Header and downpipe w/ high flow cat (CA CARB Reasoning)
take out all the trash, clothes, hub caps
and you've got 30+ hp
Reactions: brian v
How much power does the Trifecta tune give the 1.8?
If I remember correctly, it helps but not that much(not much more than regapping the plugs did). Still doesn't beat the turbo in my Eco.
Res Del
Aem Dry flo
I did spark plugs to .35 and was experiencing spark blowout. so i gapped to .32, still experienced spark blowout, now set all back to .28 and its best. on a 1.8 MT.
The 1.8 tune should adjust timing and fuel/air to help. A good intake and flowing exhaust would be good, too. Not much more you can do, from there.
Why I believe the 1.4 Goofie Balls are envious that we Don't need cruise control to keep our cruzens in a straight line .
111 things less to replace also ..
0.28 is recomended spark plugs Gap which is fine and dandy . which gives us the advantage over speculators .
We have a higher torque curve too . no waiting for that turbo to catch up .
What does cruise control have to do with keeping in a straight line? I use it to avoid speeding tickets as on a trip the car is so quiet you just don't notice the speed creeping up unless you constantly watch the speedo.
Reactions: brian v
Get H U D .
It sounded good . Plus the Smurf stole the last remaining steering wheel with cruise control for under $100.00 .
Get H U D .
Everything my car has is factory, including a sunglass holder above the drivers door where the grab handle would be. I use mine for a spare pair of regular glasses.
Reactions: brian v
Wanna buy some wheels fer yer diesel cruzen ?
Actually some made in the U.S.A. wheels fer yer Made in Australia Diesel Cruzen ?
I am actually looking for a spare that matches my road wheels, the current spare is a 6.5 X 16 inch steel, while the road wheels are 17 X7 inch alloy.
1 - 14 of 14 Posts
