Hello everybody, i am owner of Chevy Cruze 2010 1.6 83kw europe version with 82000 km. Next year i plan to do first 10year maintenance so can somebody suggest what all i should replace?
Everything, or nothing. Really depends on your viewpoints .....LOL
Find the owner's manual and compare it to what a mechanic you trust says, and then do as much as what you can afford
BAM.
Easy just check owners manual and do it all. It’s gonna be a bit pricy but will help in the long run. Flushes:radiator,brakes,clutch (if applicable), transmission. If timing belt you’re probably dude if chains probably not. Cabin and engine air filters. Clean and relube brake caliper pins.
Reactions: obermd
When you look at the list, consider how many of those items you can do yourself. The cabin and engine air filters are relatively inexpensive and easy to do, for instance. (The hardest part is putting the junk back into the glovebox.)
