1 - 1 of 1 Posts
#10317: Service Update Malfunction Indicator Lamp (MIL) - Brake Apply Sensor (BAS) Re
Subject:10317 - Service Update for Inventory and Customer Vehicles - Malfunction Indicator Lamp (MIL) - Brake Apply Sensor (BAS) Replacement - Expires with Base Warranty
Models:2011 Chevrolet Cruze
Equipped with Automatic Transmission
This service update includes vehicles in dealer inventory and customer vehicles that return to the dealership for any reason. It will expire at the end of the involved vehicle's New Vehicle Limited Warranty period.
Purpose
This bulletin provides a service procedure to replace the brake apply sensor (BAS) on certain 2011 model year Chevrolet Cruze vehicles equipped with an automatic transmission. These vehicles may have been built with a BAS that may not function properly, indicated by the illumination of the malfunction indicator lamp.
This service procedure should be completed as soon as possible on involved vehicles currently in dealer inventory and customer vehicles that return to the dealer for any type of service during the New Vehicle Limited Warranty coverage period.
Vehicles Involved
A list of involved vehicles currently in dealer inventory is available on the "Service Update Bulletin Information" link under the "Service" tab in GM GlobalConnect (US) or attached to the GlobalConnect message (Canada) used to release this bulletin. Customer vehicles that return for service, for any reason, and are still covered under the vehicle's base warranty, and are within the VIN breakpoints provided below, should be checked for vehicle eligibility.
Year - Division - Model - From - Through
2011 - Chevrolet - Cruze - B7100215 - B7103497
Parts Information
Parts required to complete this service update are to be obtained from General Motors Customer Care and Aftersales (GMCC&A). Please refer to your "involved vehicles listing" before ordering parts. Normal orders should be placed on a DRO = Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO = Customer Special Order.
PN 22769186, sensor, will not be eligible for RIM.
Part Number Description Qty/ Vehicle
22769186 Sensor, Brk Ped Posn 1
13281351 Bolt, Brk Ped Posn Sen 1
Service Procedure
  1. Remove the brake apply sensor (BAS).
    3.1. Disconnect the electrical wiring harness from the switch. While holding the connector, on the harness, press the connector down. Pull on the harness to remove it from the vehicle.​
    Note: Do NOT loosen the screw to remove the BAS. Tighten the screw to a torque greater than 8 N·m(71 lb in). The screw head will break off. Discard the screw head.
    3.2. Remove the BAS screw.
    3.3. Slide the BAS to the left to remove it from anti rotation pin.
    3.4. Discard the BAS.​
    Note: The new BAS, P/N 22769186, is white.
    Install a new BAS.
    4.1. Slide the BAS from the left to right position on the brake pedal assembly.​
    4.2. Make sure that the fork (1) is aligned with the pin on the brake assembly.
    4.3. Line up the screw (2) to the BAS hole and then fasten. Tighten the screw to 3 N·m(27 lb in).​
    Perform a Brake Pedal Position Sensor Calibration.
    Note: Do not apply the brake pedal during the brake pedal position (BPP) sensor calibration procedure. Any movement of the brake pedal during this procedure will cause the calibration procedure to fail. If this occurs, the sensor calibration must be repeated. Brake pedal position (BPP) sensor calibration must be performed after the BAS switch or body control module (BCM) have been serviced. The calibration procedure will set the sensor home value. This value is used by the BCM to determine the action of the driver applying the brake system and to provide this information to the vehicle subsystems via serial data.
    5.1. Apply and slowly release the brake pedal two times.
    5.2. Apply the parking brake.
    5.3. Place the transmission gear selector in the "P" PARK position.
    5.4. Connect MDI and GDS.
    5.5. Clear all BCM diagnostic trouble codes (DTCs).
    5.6. Navigate to the Vehicle Control Systems menu.
    5.7. Select Module Setup menu item.
    5.8. Select BCM menu item.​
    5.9. Select the BPP Sensor Calibration procedure and follow the directions displayed on the screen
  2. Perform ECM BAS Home Learn Procedure.
    6.1. Put the ignition key in the RUN position (no crank).​
    6.2. Apply and slowly release the brake pedal two times and then wait 2 seconds.​
    6.3. Repeat Step 6.2 eight times.​
1 - 1 of 1 Posts
