If you have the means, please tear down the engine and take a look at the oil pump seal for us. That would go a long way to helping us document the few engine failures we've seen with these engines.
that's not normal 🕵️♂️🤷♂️ sounds like you had rod knock for a short time.. unlucky, but at highway speeds 😑At 119k one of the connecting rods was sent through the side of the block with very little warning. I was on way home cruise set on highway goin 70 and i got a faint smell of oil. I was passing a semi with the window down and the car started making noise at first i thought it was the semi. By the time i got by him i realized it was my car. I was about 3 miles from home and i was trying to make it home without a tow and when i went up the next hill engine noise got loud and then boom. Rod through block pieces all over highway. I worked last weekend almost got engine out of car found another one to drop in we will see how this engine swap goes.
What do you mean, 2 cycles - like from 100% to 0% then you reset it to 100% and go back to 0%, then change the oil?Most of my miles are highway i change my oil every 2 cycles of the oil change which i believe puts me at around 6k per oil change. Lifetime mpg I’m not to sure as i have the car torn apart still. But i have done maitenance myself timing chain i drained the transmission twice and filled other then that it’s just been brakes and oil. Been a good car until this.
Condition/ConcernOn my Cruze a cycle is 3,000 miles from 100-0. Been that way since i bought it with 30k on it if you took the time to read my post you would see i said around 6k miles then i change the oil. Love how everybody has to get their opinions in and jump to conclusions.
Well, you have a US flag on your post indicating you are from the United States and you are talking about the 2.0 Diesel in the 2014-15 Cruze forum. If that is you, then it is 7,500 miles and not 3,000 miles. So yes, I was making some assumptions.On my Cruze a cycle is 3,000 miles from 100-0. Been that way since i bought it with 30k on it if you took the time to read my post you would see i said around 6k miles then i change the oil. Love how everybody has to get their opinions in and jump to conclusions.
