1 - 20 of 30 Posts
Trying to find out why the 12v plugs on the Cruze won't "Fast Charge" my phones with an Anker Quick Charge 3.0 USB charger plugged in. I have 3 if these chargers and all work fine in my truck and will Fast Charge our phones. But when plugged into either of the Cruze 12v outlets I am only getting slow charging.
That's because the 12V chargers in the Cruze don't transfer enough electricity for fast charging.
2013 Cruze LT
How are you plugging in a USB charger?
USB charging is a mess. Be amazed it charges at all.
The Chevy USB ports use Apple Charging. Probably 1A.
2013 Cruze LT
Most GM output a max of 15amps from the cig lighter. No more.
Again, OP is using a cigarette plug adapter, not the built in USB.
Do you have any literature to prove this or give specs for the 12v plugs?
No. The only way I've gotten anything to fast charge is to use a fast charging adapter in a 110/120V outlet. I figured that the 12V outlets in most vehicles weren't capable of fast charging.
Ugh fine.
Assuming there is nothing wrong with the charger... It’s inductive effects on the 2 data lines. Probably something to do with the design of the outlet on the Cruze combined with the design of the Anker charger.
To fix it? I have no idea. You can try a different brand which is maybe more insulated. Or an extension thing maybe.
2012 Cruze Eco 6 Speed
Ive had problums also. My phone would be plugged in and says its charging but does not charge and the battery percentage goes down ?
2013 Cruze LT
Same if I use the USB port in the center console, if I use an adapter like OP is, I get a slow but steady charge. Definitely no Quick Charge.
Reactions: Diamond193
Discussion Starter #17
Works fine in my 08 F150
Reactions: Booger
Everytime i have your problem. And it's always the same problem. Time for a new cable.
Have you tried a different cable to see if new might be defective? Maybe the plug also.
1 - 20 of 30 Posts
