1 - 20 of 25 Posts
Saw your post and checked my '14 CTD headlights, found passenger side has amber bulbs with clear lenses while the driver's side has same amber bulbs but amber lenses. I'm not orig owner, but since they differ I assume the passenger side was replaced, probably lens broke like yours.
Here's some recent discussion on the topic:
http://www.cruzetalk.com/forum/36-gen1-audio-electronics/146425-directional-signal-lens.html
http://www.cruzetalk.com/forum/25-gen1-service-issues/201506-headlight-signal-bulb-cover-broke.html
Reactions: Dngrsone
Personally I wouldn't mess with trying to split open the headlight, not worth it. RockAuto has OEM replacement headlight assembly (L or R) for about $75-80.
Since the outer clear plastic housing tends to haze after 5 years I'll probably just replace both at that point. (Tried those lens restoration kits, they work for about a year). Replacing glazed, broken headlights really enhances the look of your vehicle.
Reactions: Dngrsone
Link please
Sent from my SAMSUNG-SM-G870A using Tapatalk
So would these work on a 2015 Chevy Cruze LTZ RS?
This part is out of stock at Rock Auto. The same part # is listed for both the 2105 Cruze 1.4L gas and 2.0L diesel models so it SHOULD work for your CTD.
If it comes back in stock and you order it and find it doesn't work, I'm sure they will take it back since their website would be incorrect.
So does every headlight assembly do this? I'm under warranty but not sure it's worth the hassle
Sent from my SM-G935V using Tapatalk
The amber reflector happened in 2013 or 2014. The early ones didn't have it, so they didn't fall off, but it seems to be happening to the majority of later lights. They went back to the clear reflector as replacements.
Mine is a 9/15, so it might have been on those as well
Holy crap, I just checked and I have the exact same issue. Why would they be different colors? And how do you get that piece back in place?
1 - 20 of 25 Posts
