You mean it won't " pop open" when you release the latch?
You'll see two torsion bars inside the trunk that act as the spring mechanism to keep the trunk lid open. Spray with silicone and displace any moisture that might be on the pivot points.
If you're referring to the outside switch, there were problems with early ones being sealed from rain entering them. Dorman has replacement switches.
