Ground strap?
Or more likely the EGR valve is clogged.
Are you running a tune?
Engine wise all stock, I have no interest in a tune.
Yeah if the battery is more than 3 yrs old, that's where I'd start. Assuming you already did the negative batt cable.42k miles on clock, car won't start, first time car try's to start and run and actually starts but then seems like it's not getting fuel and shudders and dies. I think I am going to replace the battery and see if that helps it, if that doesn't work tow to dealer for repair. The battery seems weak after a couple attempts to start.
I have driven over 400 miles on this tank so far, so that does not seem likely. My normal driving now is 700-1200 miles a week, so I have a fresh tank of fuel at least once a week.Actually.....your description makes me wonder if you didn't get bad fuel. How long ago (miles) did you get fuel.
This 'wants to run momentarily' business has me on the fuel quality thought.
That's fine on my side. I also plan to show a pic of what EGR looks like installed and it's location on the engine. Prior to this problem, I didn't know where it was located.title should be edited to reflect the repair
no one in the future will find it otherwise
assuming you reused the gasket?That's fine on my side. I also plan to show a pic of what EGR looks like installed and it's location on the engine. Prior to this problem, I didn't know where it was located.
I left my little tool pack in the trunk, just in case I ever need to remove on the road.
The forum and all saved me several hundred $$$ since no tow bill and the dealer just replacing the valve vs cleaning it.
I did, would be better to replaceassuming you reused the gasket?
is it traditional gasket material or ?I did, would be better to replace
I didn't even look...should have...I did test the EGR to make sure it would close just by hooking up the EGR not installed, yikes it's a smoky mess, shut car off quickly. Amazing it lasted as long as it did. The emission system has issues for sure, but dang it cleans up the soot and mess pretty wellis it traditional gasket material or ?
i considered inspecting my egr couple mos ago, but didnt wanna screw the gasket up
