Originally it didn't. Due to the volume of all the failures with it they "extended" the coverage. My woes with the coolant started with the water outlet and the upper radiator hose.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Originally it didn't. Due to the volume of all the failures with it they "extended" the coverage. My woes with the coolant started with the water outlet and the upper radiator hose.I'm surprised a water pump warranty outlives all the other warranties on the vehicle
I'm confused, are you saying you spent 1,200 USD to get a water pump replaced on a Cruze? It is true there is an extended service coverage on the water pump. I can't imagine a Chevy dealership would put in a non OEM water pump. Even so, 1,200 is INSANE for a water pump replacement on a Cruze.Hi;
I spent $1,224.63 at chevy deal, for my 2011 chey cruze.
I have Warranty Solutions for my coverage, who said
the Chevy dealer was responsible for the work, because there is a 10yr/ 150.000 factory Warranty on the car
Chevy is telling me they are not responsible because the water pump they put in was after market.
I don't know who's telling the truth and I'm out of $1,224.63. Is their something I can do.
Thank, Keith
I interpret your question as: The dealer would not warranty the water pump because the one that was installed/removed from the engine was a non-GM part.Hi;
Thank, Keith
They usually send out letters about the special coverages to the original owner of the car (I got several for my 2012).I was getting my snow tires off on May 1 when i realized my fan was running. I looked at my gauge and i saw that my car was running hot. I checked the fluid and sure enough - none.....so did the usual brought it to the mechanic and he told me that it was the pump. Now.....if if didn't have a friend that is the up and up on GM I wouldn't have known it had an extended warranty. So my question is how does one be in the know of these things if they don't get letters. Can you sign up for emails? Are there other forums ? My car is my investment and I want to hear about how the cam sensors leak and all the other common problems of the car.....My car is my investment and I want to take good care of it
I think you should call GM corporate and complain. I for the life of me can't figure out why a dealership would not use OEM parts. Unless I'm missing part of the story, this job should NOT cost 1,200 dollars. In the meantime, I would not do any business with the dealer because the price alone is insane.I was told I needed a water pump, this was on Saturday June 9th 2018. The Chevy Dealer changed the water pump, thermostat, four bolts(which I Found three bolts under the hood)and coolant the price was $1,224.63. Chevy Dealer called my Warranty company on Saturday and they were closed, So I paid the money and called My warranty company they said that there was a factory warranty for the car and that the dealer was responsible for the water pump, because of the 10 year/ 150.000 mile extended factory warranty. I then called the dealer and the said that they put in an after market water pump and the are not responsible. I don't know who or what to believe. but I'm out of $1,224.63.
Thanks, Keith
How did you pay? If it was by credit card dispute the charge. First contact the Service Manager, then the Store manager if no results, Chevrolet Customer might want to become involved, and your last recourse is Small Claims courtI was told I needed a water pump, this was on Saturday June 9th 2018. The Chevy Dealer changed the water pump, thermostat, four bolts(which I Found three bolts under the hood)and coolant the price was $1,224.63. Chevy Dealer called my Warranty company on Saturday and they were closed, So I paid the money and called My warranty company they said that there was a factory warranty for the car and that the dealer was responsible for the water pump, because of the 10 year/ 150.000 mile extended factory warranty. I then called the dealer and the said that they put in an after market water pump and the are not responsible. I don't know who or what to believe. but I'm out of $1,224.63.
Thanks, Keith
Must be, just received a letter from Chevy saying so. Usual information to those unfamiliar with what a water pump does, and tell-tail symptoms to help determine if the water pump did fail.
If it already did fail, and you paid to have it replaced, a form is enclosed so Chevy will give you a refund.
First time I have ever received a letter like this, and 150,000 mile warranty! Ha, would like to receive more letters like this for other common failures.
What did I do with this letter? I framed it of course.
Extended warranty on water pump is still applicable if you are under 150,000 miles.Just found out my water pump.is cracked and needs replacing. 2014 cruz i bought used. Is the factory extended warranty still valid? Will Chevy replace free of charge? Help before i spend big $$$.
Prices are ridiculously steep but stuff pointed out is all common leak points on these cars.I am a PE for 40 yrs. Do all work on my vehicles since 1977. My daughter bought a 2012 Cruze LT NEW. She recently lost coolant and I checked it. Failed water pump. Pour water in the reservoir, it leaks out of the seal without even adding pressure. She used her AAA to tow it to the dealer she purchased from. Tsb says the customer is not to be charged. They said the water pump is covered, but refused to replace it unless she paid $3200 worth of unrelated work! Some warranty! She had to tow it home at her $80 expense. She stays home with her 3 year old. Ridiculous and likely not legal. Any suggestions? I will fix it, but the dealer skates?
