How did you measure their heat energy?They're produce almost the same amount of heat plus i haven't had them on for more than 5 minutes
i used a thermometer gunHow did you measure their heat energy?
Granted, the time is short, but unless they're LED, I'd almost guarantee it's more heat.They're produce almost the same amount of heat plus i haven't had them on for more than 5 minutes
Quick question why would you have reverse lights on for more than 10 minutes lolNice. I think. But how much heat do they generate and retain after 10 minutes compared to the stock bulb?
Save gas!Quick question why would you have reverse lights on for more than 10 minutes lolNice. I think. But how much heat do they generate and retain after 10 minutes compared to the stock bulb?
You mind snagging a picture when it is completely dark? I'm curious.It's a local business here in Georgia if you want a set you can get it through me
SureYou mind snagging a picture when it is completely dark? I'm curious.
Umm, the title of the post says led.Granted, the time is short, but unless they're LED, I'd almost guarantee it's more heat.
They have all the bulbs you need, not just fogs: Chevrolet Cruze LED and HID LightingDiode Dynamics only shows LED fog lights for the 2014 Curze.
