1 - 1 of 1 Posts
Hi CT.com, i am hoping someone can point me in the right direction.
i took my 2012 LS Cruze in for an oil change and 1 day after the service the CEL came on and it started to hesitate under acceleration. i hooked up a scanner to the OBDII port and it shows a P0016 error code. kinda strange since it ran fine prior to the oil change. searched all over the web and came to the conclusion that the intake camshaft position sensor was failing. so instead of just replacing only the intake sensor i replaced both the intake and exhaust camshaft position sensors. to my disappointment, this did not help the hesitation upon acceleration.
is there a process to reset the ECM to read the sensors correctly? please help:sad::sad::sad:
1 - 1 of 1 Posts
