Thanks for sharing...how’s the ride compared to the stock setup?I couldn't find much info on gen2 wheel fitment. Hope this helps anyone who was wondering.
20" Niche wheel. 225/35/20 tire. No rub/lowering.
51.9 hwy mpg at 75 mph with stock wheels down to 49.5 mpg with new. Manual diesel 1.6.
View attachment 249577 View attachment 249585 View attachment 249593
I went with the higher tread wear due to my commute and sound wise I don't hear a difference. I may be a bad judge cause my other ride is a F250 diesel with 37" tires, so I'm use to the noise.Thanks for sharing...how’s the ride compared to the stock setup?
Yes that's them. They are drilled to 5x105 bolt pattern.Niche Milan? What backspacing? I'm not finding these in a 5x105. Or am I wrong on the bolt pattern?
Hubcentric?Yes that's them. They are drilled to 5x105 bolt pattern.Niche Milan? What backspacing? I'm not finding these in a 5x105. Or am I wrong on the bolt pattern?
Yes, hubcentric.Hubcentric?
Definitely but when you're putting 20s on your Cruze I'm sure that isn't a concern hahaAren’t speedo and mpg numbers off, taller than factory setup.?
Yo, that's sick. You have given me encouragement I was going with some 19's for my build and since you got 20's I think I'll be fine. Much appreciated.I couldn't find much info on gen2 wheel fitment. Hope this helps anyone who was wondering.
Any rubbing issues while turning.I couldn't find much info on gen2 wheel fitment. Hope this helps anyone who was wondering.
If u have a gen 2 cruze 2016+ it's a stupid back spacing Gm decided on when gen 1s are 5x 114, it's so irritating.Niche Milan? What backspacing? I'm not finding these in a 5x105. Or am I wrong on the bolt pattern?
