2010 1.6 gasoline 5 speed manual transmission oil change
1298 1
can someone guide to me how to change 2010 1.6 gasoline 5 speed manual transmission oil? there have a topic but photos doesnt exist.
1 - 2 of 2 Posts
There's a fill plug at the top, using a metric hex bit, and a drain plug at the bottom. The drain plug at the bottom is next to the sub frame on the left side of the car (if you were sitting in it). You may need to place a wrench over a hex bit to loosen the drain plug. Make sure to remove the fill plug FIRST before removing the drain plug, as it may be stuck. Fill 2.5 liters of fluid.
1 - 2 of 2 Posts
