Hi everyone
I have a 2010 jg holden cruze with 157000kms on the clock. There is 1 issue with the car it starts and idles fine then when you drive it and start to load the engine up when its temperature is cold the car jerks backwards and forwards and engine light flashes until you push the clutch in. The problem goes away once the engine comes up to temp then the car drives perfect no problems at all. You can leave for an hour or so and then drive it and will be fine due to still being warm. If you leave it over night when you go to drive it the same problem happens with jerking and the engine light appearing. If i leave car idling for half an hr before driving the car is warm and no problems runs perfect. Has anybody got any suggestions to fix it.
Thanks
Thanks
