I already know the 2011 does not have the apparent software to tune for e85. Both BNR and ZZP say the same thing. Is there a way to swap to 2012 ecu? I want the performance gains of e85 but not sure if its possible?
So its possible to put a 2012 ecu that is programmed to my vin in and it will work fine? The global architecture system will not be affected? And I know will need 60lb fuel injectors plus flex fuel sensor installedYou could always get a new ecu and reprogram the car... E85 also requires different injectors.
I cant find any info if it will work for sure or not. Someone has to have a 2011 and figured out how to run e85 or flexfuelThe car is the same so I don't see an issue with it. We have done it before on my friends truck as well as on an older camaro SS.
Or they just put in a 2012 ECU and reprogrammed it.I cant find any info if it will work for sure or not. Someone has to have a 2011 and figured out how to run e85 or flexfuel
I wasn't sure if it was possible to tune for straight e85 or not. I think it is something with the software on 2011 that isn't capable of using the flex fuel sensor. I would like to run e85 primarily but if I get somewhere it's not available then be able to use premium.I have a 2011 Cruze 1.4L and run straight E85. The computer is missing a pin or something required for the flex fuel sensor so it has to be straight E85. Needs injectors and tuning![]()
Yeah either carry a small can of E85 to get you to a known servo (Kwik-E-Mart) if you run out or a can of 98 (93 I think) and switch the tune when it runs out. I'm lucky because I have E85 a few minutes away, that's really the only reason I decided to change to a full E85 tune...I wasn't sure if it was possible to tune for straight e85 or not. I think it is something with the software on 2011 that isn't capable of using the flex fuel sensor. I would like to run e85 primarily but if I get somewhere it's not available then be able to use premium.
That is dangerous though because not every stations E85 is actually E85.I have a 2011 Cruze 1.4L and run straight E85. The computer is missing a pin or something required for the flex fuel sensor so it has to be straight E85. Needs injectors and tuning![]()
yea I mean that is the thing, you need the sensor to be safe and be able to drive anywhere.I wasn't sure if it was possible to tune for straight e85 or not. I think it is something with the software on 2011 that isn't capable of using the flex fuel sensor. I would like to run e85 primarily but if I get somewhere it's not available then be able to use premium.
